Question about Dyson DC28 Animal Bagless Upright Vacuum
How do you get it to click/stay in the upright position? I just used it and I can't get it to stay in the upright position for storage...Thanks in advance for you help.
    Master:
  • Dyson Master
  • 403 Answers
The Dyson manuals for pretty much all of the uprights don't show any particular 'click' to full upright: they just tell you to put a foot on the bottom part of the unit and pull backward to put it into vacuum mode. There is some sort of sensor or mechanical engagement in there, since putting the system to full-upright is how you switch it from floor mode to attachment mode (coming of of the handle).
A couple of things to try - follow your manual (PDF Can be seen here Dyson DC28 Animal User Guide ) to try removing and then re-seating the hose assembly into the base of the unit (the bottom connector). I've seen other guidance to that being necessary to have the floor-to-hose switch-over work properly, which might, in turn, be the root of your problem. Likewise, with the unit turned on, see if it will switch to attachment mode (air being sucked through the top of the handle) if you push the back as far forward as you can. If it won't switch, that also points to seating of the tubing assembly not being right.
Good Luck :-)
Posted on Nov 03, 2015
4 Suggested Answers
  • 389 Answers
SOURCE: The handle will not click into the upright
Go to www.dysonmedic.com scroll to bottom of page and click on "DC04 not positioning upright fix" for illustrated solution. The DC07 is similar. If this doesn't work, post a reply here and we'll see what else you might try. Good luck!
Posted on Feb 13, 2010
Dysonteam
  • 167 Answers
SOURCE: My Dyson DC-18 won't click and stay in the upright
Hi its Darran at Dyson.
It is difficult to confirm what may be causing this, however its worth ensuring that when you lock the machine back up into the upright position position, that you push the handle slightly forward when you try to do this to help the pedal engage.
If this is not working, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
SOURCE: Dyson Rollerball wont clikc into unpright position.
I've just had the same problem! The small metal poles either side of the red push bar at the bottom of the hoover should both be in a groove/runner. The problem is that one or both of the metal poles has popped out of the runner and is stuck in one of the holes next to the runners. Gently pull the red bar from the hoover and pop the metal attachment back into the groove. Problem solved :)
Posted on May 19, 2010
I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
Sep 13, 2015 | Dyson Vacuums
My dyson DC41 animal upright vacuum clicks but doesn't stand up
If you are indicating that it works, but will not stay in an upright position, then the problem is likely a plastic part has broken.
Since the machine is nearly all plastic, it will break rather easily, and may not be repairable.
You might try to look up the Dyson company on your computer and see if they have a phone number to talk to them, but if it is made in China, there may be no spare parts available.
God bless your efforts.
Jun 17, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
My Dyson DC17 Animal Bagless Upright does not click to stay in an upright position. It works but the handle falls to the floor.
This is a common fault with the Dyson DC07 (and other Dysons) unfortunately the clip that holds the handle upright hs broken. It can be repaired, but will cost a reasonable amount to have done... I would just live with the problem and prop the vacuum cleaner against a wall when not in use.
Aug 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dc07 model, cannot get it to stand fully vertical upright. It is as if something is not sliding back into position right. Don't want to force it in case something breaks. The upright of the cleaner has...
Try this quick repair and see if this fixes your Dyson in terms of not going in the upright position: This is a frequent problem that we see come in on Dysons. If this doesn't fix it, please feel free to just use the clarification request and let me know this didn't fix it.
Step 1.
Turn power off and unplug the machine.
Tilt the machine backward to a 45° angle.
Step 2.
  • Hold the section under the airway inspection pipe.
  • The black forward lock button must be held down simultaneously, otherwise the valve carriage will not move.
  • Pivot this section upwards until it clicks into place.
  • Release the black button once the valve pipe carriage is moved up into place.
    Step 3.
    • Tilt the machine forward.
    • The cleaner head should now slide underneath the part you have just clicked into place.
    • The machine should now stand upright.
    May 02, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
    My Dyson DC-18 won't click and stay in the upright position. Ideas?
    Kind regards
    Darran
    Apr 17, 2010 | Dyson DC18 all floors Bagless Upright...
    Mar 30, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
    The handle will not click into the upright position-only stays in "vacuuming position". How do I fix it? Linda from KY
    Feb 12, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Dyson 28 handle is stuck in the locked and upright position. Vac runs fine, just can't get the handle to release to run the vac
    On the lower right side of the body of this model is a air duct piece that can get stuck and won't allow you to use the release. Take out that piece and put it back on again to see if that will unlock it.
    Nov 30, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
    Hoover elite rewind won't stay on
    Sorry if this is stating the obvious, but it sounds as though your machine needs a new switch! Do you need help with that?
    Mar 04, 2009 | Hoover Elite Rewind Bagless Upright...
    Dyson DC28 Animal Bagless Upright Vacuum Logo
    109 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Samyfam
    Samyfam
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
