Question about Hoover Washing Machines
Washing machine power on wall machine in off position water pump runing machine will not fill up with water an go on cycle
    Genius:
  • Hoover Master
  • 1,585 Answers
Could b the door inter lock or presour switch
Posted on Apr 12, 2015
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Will fill with water but wash cycle does not start rinse &spin worksm
Needs looking at, take the top of the unit off, switch on and manually turn to the wash/spin cycle and listen for a click, if theres no click then the circuit panel needs replacing, if there is a click have another look (switch off and isolate machine) and make sure the small springs that hold the pegs near the cogs are there, sometimes they just break off being so fragile.
Oct 02, 2010 | Frigidaire FWS833A Top Load Washer
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
Washer overflowed while filling for wash cycle.
A quick test to split up your possible trouble makers:
Let the washing machine fill with water and when the washer is about 1/2 full of water unplug the washers power cord from the wall outlet. If the water keeps flowing into the washing machine with the power cord pulled the fill valve ( where the hot and cold hoses are attached to your washer ) has mechanically stuck open and will have to be replaced. If the water shuts off when you remove it's power cord from the wall outlet, try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good = on to the next trouble makers.
The water level control is responsible for shutting off the power to the fill valve and redirects the power to the timer to start the washing machine running once the correct water level has occurred. The WLC itself could be bad. The WLC uses a hose that the water level pushes air into to tell the WLC what the water level is inside the washing machine...the hose could be pinched, fallen off of the tub spout, has a pin hole, clogged up with calcium or soap curd and the WLC cannot "sense" or "tell" what is happening inside the washer.
Nov 27, 2009 | GE Washing Machines
The machine does not work
Ok this fault is telling me you have a faulty RPS(Rotor Positioning Sensor) in this machine. The RPS sensor is located in the motor Stator. To replace you need to remove the motor rotor then the motor Stator. you want to be careful with this part when fitting it as they can break.
Please rate my advice.
Cheers
Steve
Mar 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Leaking water at the end of cycle
Watch your drain line in the wall when the final pump out begins.
May be a sewer problem.
Start a cycle. After the fill, advance to final spin and watch drain in the wall.
Feb 25, 2009 | Whirlpool Washing Machines
Washer won't stop filling
if you can turn the washer off while it is still filling. and the water continues to enter the machine you have a bad inlet valve.
Do me a favor turn the washer to fill, with the washer still running unplug from the wall. If the water is still entering the unit you have a bad inlet valve
Jan 05, 2009 | Roper RAS8445KQ Top Load Washer
Washing machine it shuts down water filling cycle
First thing to check is the filter,
DISCONNECT power
open the bottom pane (3 screws on bottom front lip)
in the cent is a large removable filter ,
set a pan or rags under it ,there will be water.
clean out any debris an be sure the pump impellers move freely.
let me know if that fixes it.
Jan 29, 2008 | Maytag MAH6700AWW Neptune Front-Load...
E20 error?
Plug off the wall first before these jobs. Remove rear panel.Check your filters and pump. Most probably you have a block in your pump. You have to drain out water from the machine by lowering the hose behind the machine to floor level, be prepared, bucket, etc. Dont forget to fix hose behind at very same position in wall drain. Your filter panel is in front bottom right of machine.
Things shd be fine, rate me pl.
Oct 14, 2007 | Frigidaire GLTF2940ES Front Load Washer
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Washing Machines Logo
29 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
Chris Hall
Chris Hall
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
