Question about Coffee Makers & Espresso Machines
MR coffee maker only beeps
BY pushing the button to start brewing the pstx91 coffee maker only beeps.
SOURCE: MR COFFEE FTX49. Brewing starts, then stops
Mine just started to do the exact same thing. So I decided to clean it using the "Clean" program and just water. I put the brewer through the cleaning program 3 times - each time it would brew water from 12 cups to 8 cups, I'd tap the brewer on the countertop, it would brew from 8 cups to 4 cups, tap it again, and it would brew the remaining cups. So, I called the Mr. Coffee help line (800-672-6333). The most-likely problem is that the hose is no longer attached in the water reservoir. The help line suggested that I take it in to a service center. I live in Urbana, IL and the closest service center is in Oak Lawn, IL - 2 hours away from me!!
Here is my solution:
1) Buy another coffee brewer.
or
2) Smash your current Mr. Coffee brewer into a million pieces (this relieves stress) and go buy another coffee brewer (probably stay away from Mr. Coffee products).
Hope this helps.
Frustrated in Urbana
Posted on Oct 19, 2009
nblady
  • 206 Answers
SOURCE: set time to start brewing in the morning
The following instructions shuld have you in hot coffee in the am.
S E T T I N G T H E C L O C K A N D D E L A Y B R E W T I M E
On programmable models CGX20/CGX23 & CGTX84/CGTX85 only
To Set the Clock:
1. Plug the power cord into a standard electrical outlet. The clock will flash on the control panel to
indicate that the time has not been set yet.
2. Press and hold the HOUR and MINUTE buttons until you
reach the current time. The PM indicator will light on the left
of the display.
The clock is now set!
NOTE: Pressing any button before setting the clock will cause
the clock to start keeping time from 12:00 a.m. You must set
the clock if you want to use the Delay Brew feature.
To Set the Delay Brew Time:
After setting the clock, simply press and hold the SET DELAY
button (Figure 1), and set the brew time by pressing the HOUR
and MINUTE buttons. The PM indicator will light up on the
clock display.
The Delay Brew Time is now set!
NOTE: To activate the DELAY BREW cycle, see the “Brewing Coffee Later” section.
To check the programmed time, push the SET DELAY button. The display will show the time you have
programmed the coffee to brew.
http://www.mrcoffee.com/Manuals/MANUALS/CGX20_43_62164399.PDF
Posted on Dec 30, 2009
1800PartsFix
  • 36 Answers
SOURCE: BVMC-PSTX91 MR COFFEE....ONLY USED ABOUT 15 TIMES
Mr.Coffee guarantees their machines for one year from the date of purchase. If you still have a receipt I would contact them. If not there could be a problem with the board on the inside of the machine. Which, unfortunately, is not available yet to purchase so your machine can be fixed.
Posted on Nov 12, 2010
  • 5 Answers
SOURCE: as soon as i turn
Check the plate where the decanter sits and see if it's hot if not after turning it on then the element that heats the water is open or the thermostatic switch is defective and stuck open on the thermal fuse open. If you do not have the knowledge and equipment to check the things I mentioned and you have only had it for a short time take it back to the store. Sometimes you can call the number located on the warranty and they will tell you to cut the plug receptacle off and mail it to them and they will send you a new one.
Posted on Nov 30, 2010
SOURCE: coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Posted on May 27, 2012
Coffee stopped brewing well, coffee now brews weak. Even with increased coffee grounds. Clean button won't turn off. Even after 2 clean cycles.
Chances are there are built up scales inside the brewer. Are you using regular water? If so, you may have to descale it. Look for a food safe descaling chemical which you may have to flush with clean water in several cycles. Another solution is to take it apart and clean it. Problem is, you have to be skilled to do this.
Jun 19, 2016 | Mr. Coffee BVMC-PSTX91 10 Cup Programmable...
How do I clean Mr. Coffe, Model BVMC-PSTX91. I lost the manual that came with a little pkg of to make a solution for cleaning. Please advise. Thank you
I use a quarter cup of white vinegar and the rest water. do it just like making coffee but don't put grounds in it. then run several pots of water through to rinse it out.
Sep 28, 2014 | Mr. Coffee 072179228578 12 Cup Coffee...
My Mr Coffee beeps three times when I push the brew button and will not brew
If the carafe, the filter basket, or the water reservoir are not all properly seated, the unit will beep 3 times to let you know it cannot brew until everything is in place.
This happens to me sometimes when I push the button right as I'm putting the carafe in place. I just need to wait a few seconds.
Oct 03, 2013 | Mr. Coffee 072179228578 12 Cup Coffee...
How do i fix my mr coffee model fhx33
Maybe you did the same thing as me - left the water in the dispenser instead of pouring it into the main body of the pot!
Jul 17, 2012 | Mr. Coffee 072179228578 12 Cup Coffee...
I turn on my Mr. coffee maker and it just beeps and won't brew any coffee. What could it be?
Tried to clean it, everytime you press the brew button it just beeps and if we try to set it to clean it sounds like it tries to turn on but nothing happens.
Apr 27, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
BVMC-PSTX91 MR COFFEE....ONLY USED ABOUT 15 TIMES AND NOW LONG BEEP AND WONT BREW...THE BEEP WONT GO AWAY UNTIL YOU TURN OFF THE MACHINE
Nov 12, 2010 | Mr. Coffee TFTX85 Coffee Maker
Clean light won't go out, can't use delay brew feature.
Try unplugging it for several minuets & see if it clears it..
Jul 08, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker beeping
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
