Question about Garden
I disassembled my carburetor and fuel lines looking for a fuel problem. Reassembled with new carburetor and not sure how fuel lines are routed. A picture or diagram would be greatly appreciated.
  • 85 Answers
Use alcohol free gas and this will not happen.
Posted on Feb 22, 2016
  • 384 Answers
SOURCE: mcculloch 4600 chainsaw fuel line routing
Shouldn't be that hard to do. Possible paths 1) Run hose from tank fitting to Carb fitting. 2) Run hose from tank to shut-off vale to Carb 3) Run hose from tank to shut-off to prime to carb 4) run hose from tank to shut-off to prime to filter to carb. Omit any item not on your saw.
Posted on Jun 12, 2009
SOURCE: Need diagram for fuel lines on craftsman chainsaw
There is two sizes of line. I see the large one goes to the large port on the primer button and then to the fuel tank. The small one goes from the primer button to the carb. The problem is there are two hose connections on the carb. I believe one is a vent, but I am not sure what one it is. I have a 36cc 2-cycle model 358.352161
Posted on Jun 22, 2009
dontbother10
  • 2220 Answers
SOURCE: I NEED A DIAGRAM OF THE FUEL LINE TO THE
What you request doesn't exist. An IPL containing fuel system parts with very little detail can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
The fuel system parts can be found on the "Engine Assembly" and "Handle & External Assembly" illustrations.
e17de8d.gif Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
HTH
Lou
The serial number you provided allowed me to find the correct IPL for your saw Type 6 (-6 from serial number). Thank You.
If you feel Poulan should provide better illustrations please contact them here: http://www.poulanpro.com/node4033.aspx There is a toll free telephone at the bottom of the page.
If you contact them and aren't satisfied with their reply, please elevate your concern to their parent company (Husqvarna) here:
http://www.husqvarna.com/us/homeowner/support/customer-support/
Posted on Oct 29, 2009
dontbother10
  • 2220 Answers
SOURCE: McCulloch 3216 fuel primer and gas tubes routing?
  • If the saw is equipped with a primer bulb, the output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as it inflates).
Take lots of notes and a few digital photographs will help with reassembly. HTH
Lou
Posted on Nov 01, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel line diagram for 358.352160
It is most likely a Poulan almost all are. The IPL is the only manufacturer supplied fuel system detail, it lists components, part numbers and very little routing detail. and is usually spread over multiple illustrations.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
I think you'll find the short video, a few notes and a typical system most helpful. Any local saw shop can provide replacement hose.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
Take lots of notes and a few digital photographs to help with reassembly.
HTH
Lou
Posted on Nov 19, 2009
Carburetor change
Primer bulbs pull fuel from the carb, into the bulb and dumps it back to the tank, if you have re connected the hoses to the primer the wrong way around it will try to force fuel into the carb and make it flood.
Jun 01, 2013 | Poulan Garden
My cub cadet weedeater wont speed up when i give it gas
Hi gburks83...
I will include a fuel routing picture also..
Sounds like you have dirt/debris in your caburetor jets,fuel passages or a diaphgram that is becoming non-flexible.
Check/Clean/Replace your Air Filter, a dirty air filter can make your engine run to rich with fuel.
Note: ALWAYS USE COMPRESSED AIR TO CLEAN YOUR JETS AND PASSAGES, VERY IMPORTANT.
Note:Before you disassemble the carburetor:
Write down on a piece of paper or take a picture of how the linkage attaches to your carburetor for later reference when you go to reinstall your carburetor.
Mark each piece with a awl, or some kind of instrument that will make an alignment scratch before you disassemble the carburetor into separate pieces.
That way you will know which way it goes back together when you reassemble it.
Sometimes you can get by with priming the carburetor or by using a very small shot of starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Be sure to check your fuel tank for water and dirt/debris, if there is water/debris then you need to clean your tank.
Check you fuel line condition after a while they will degrade and need replacement.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of weedeaters.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a picture for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.
The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle weedeater with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
The diaphgram may look good and flexible, but it can be deceiving and not act as a fuel pump as it should because it has become too hard and will cause hard starting,start and run and shut off, etc.
When you clean your carburetor, I recommend that you use a laquer thinner type cleaner to clean and dissolve the laquer build-up in the float and needle jet passages.
Be sure to remove all plastic and rubber parts before using the laquer thinner because it can dissolve the plastic parts and render them unuseable.
Be sure to use COMPRESSED AIR to blow out all the fuel and air passages.The higher air pressure is needed to blow some of the trash/debris from the fuel or air passages.
Be careful when blowing out the passages, because there are sometimes small rubber type seats in the bottom of some of the passages.
Keep in mind that the float (if you have one) for the carburetor must be level when you go to reassemble the carburetor or follow the instructions you get with the carburetor kit, or you could also ask the parts man that you get your kit from.
When you clean your carburetor and remove the jet screws, you will first need to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first and then turn them back out to their original position before you started.
Note:
The little spring inside of the carburetor goes under the float arm.
That is where your fuel inlet needle/float valve is located...on the arm at the end.
Normally there is a small indetion in the carburetor base and a small protrusion on the underneath of the float arm where the spring will be in the right postion for installation.
The spring will set in the indention and you will install the float arm with the needle/float valve and float rod into position over top of the spring,you will push down until it is in position and then you can tighten the screw that holds the float arm assembly in position.
Once you have your carburetor cleaned/rebuilt that should solve your problem.
Please take time to rate me thumbs up
Sep 27, 2011 | Cub Cadet Street Sign- tractor lawn riding...
Ihave a poulan forester3300 chainsaw I need to know how to conect the gas lines corectly. also Ineed to know the carbruater adjustments.
Hi eordubyddub...
I have included a routing picture of the fuel system.
I will make some recommendations to you...
Check you fuel line condition after a while they will degrade and need replacment.
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws.
When you remove your fuel lines from the carburetor be sure to take a picture or make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Normally the big line will be the line the fuel filter is connected to inside of the tank.The smaller of the two lines is the return to the fuel tank from the carburetor after it is pumped thru the carburetor by the primer bulb.
Make sure you are using fresh fuel...and oil if your using a two cycle chainsaw with the oil to the right mixture...too much oil as it can cause hard starting and excessive smoking.
If the chainsaw is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Note:
Sep 24, 2011 | Poulan Garden
I have a Mac 3200, I replaced the fuel lines and now it will start but wont stay running. Also the primer button fills with gas but is very hard to push because of gas pressure. What did I do wrong?
Hi www donbened...
I will also include a fuel routing picture.
When you remove your fuel lines from the carburetor be sure to make a drawing to how the lines are connected to the carburetor or take a pictue for later reference.
Make sure you are using fresh fuel...and oil mix if your using a two cycle chainsaw with the oil to the right mixture and not too much oil as it can cause hard starting.
Note:
Sep 22, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have a Poulan 3400, It runs good and strong for a few cuts then starts to bog down like it is running out of fuel. Any ideas on what it could be, I did install new plug and still does the sames thing.
Hi
Check/Clean/Replace your fuel filter if you have one, normally they are located in the fuel tank of chainsaws .
Note:
Sep 18, 2011 | Garden
I have a troy bilt 4 cycle (TB425cs) trimmer. The fuel line deteriorated and the filter at the end fell off. I replaced the fuel line and reinserted the filter on the end. When I prime it I can see fuel go...
Hi johnmurmello..
Here are a few things you can check to see if you got it right.
I will also add the fuel routing diagram
Sometimes you can get by with priming the carburetor or by using starting fluid and letting it run a few times like that, and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Make sure you are using fresh fuel...and oil mix if your using a two cycle weedeater with the oil to the right mixture and not too much oil as it can cause hard starting.
Note:
Sep 11, 2011 | Garden
I have a poulan pro 260 I can get it to start but it will not say running
Hi timhamilt827
reference.
If the mower/trimmer is over a couple of years old, then I recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
Note:
Fuel routing picture:
Sep 10, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Engine is bogging down
Sounds like a fuel issue. Just enough gas getting there to start it, but not enough to keep it running. Start at thefuel line to the carburetor. Make sure fuel will come out at a sufficient stream. If it doesn't, work backwards towards the fuel tank, looking for clogged fuel lines and such. Clean whatever is suspect. If you get fuel all the way to the carburetor, you'll need to clean the carburetor. Careful disassembly is critical to getting it put back together correctly. Clean your parts with brake cleaner, not carburetor/choke cleaner, paying particular attention to orifices.
Best Regards, --WoobieDog--
Jul 10, 2009 | Garden
Starts for a few seconds, then quits
You will have to remove the air breather and carburetor to make the job easier. You will then be able to access the fuel lines easier. You may also need to take the gas tank off. While you have the carburetor off, it might be a good idea to clean it as well. Use a Den Tek Brush, (used for cleaning teeth), for small ports in carb. And depending on how old your chainsaw is and how much it is used, you may want to go ahead and get a carburetor kit and replace the needle valve, small screen, and appropriate gaskets. Sounds like it might just be your fuel lines though.
Jim
May 23, 2009 | Husqvarna Garden
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
