I have pink vertical lines picture is somewhat visible what's wrong
    Top Expert:
  • Televison & ... Master
  • 75,178 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 12, 2015
legna
  • 53 Answers
SOURCE: Vertical line on KDL-32s20l1
You'll get this abnormality some times due to the signal if you're watching regular analog picture and you have your TV set on full screen, the TV will stretch the picture and you will see more defects than if you're watching it on normal picture. But if you are seeing the same problem when watching HD picture it needs to be serviced try this link I found: http://www.moniserv.com/doc/lcdtv.html
Posted on Aug 28, 2007
  • 147 Answers
SOURCE: VIZIO P42hd PS42a plasma
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Posted on Mar 30, 2009
  • 113 Answers
SOURCE: 50. In LCD samsung has pink vertical lines
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Posted on May 10, 2010
alpug
  • 1961 Answers
SOURCE: Fuzzy picture. Vertical lines
please include the brand and model of your tv also a brief description of your TV like plasma ,LCD,DLP OR CRT PROJECTOR..post back pls.
Posted on Feb 08, 2011
  • 10 Answers
SOURCE: LG DU42PX12X - red and pink vertical lines.
I know this post is old,
But I had the same problem.
I was able to fix it.
Heres a write up I did on the "How To".
I added pictures and diagrams too.
http://jasonkoller.blogspot.com/2011/02/lg-du-42px12x-plasma-tv-fix.html
Posted on Feb 18, 2011
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Jul 22, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Multiple reddish pink vertical lines going from
Hi
We can check if the problem is on the hardware(projector) itself or if from source(device connected to projector) try to turn on projector without connecting any other devices to it. If you can still see the pink line- try to remove bulb and reinstall it. If all fails and pink line still visible, there is a problem with projector. If no line is present- check settings and change input signals.
Hope this helps
Mar 26, 2010 | ASK Proxima DP6860 Plus Multimedia...
Pink/purple vertical line visible
Anytime you see visible lines running through a display, this is usually an sign of an eminent screen failure. It could stay that way for weeks or the lines could multiply and then it could fail. There is no repair for this, only screen replacement.
Feb 20, 2010 | HP w17e Monitor
Pink discoloration and vertical lines in light areas
Possibly a form of flare caused by including the light source in the image.
Jun 25, 2017 | Olympus FE-280 Digital Camera
A pink vertical line appears suddenly on the screen
Sounds like a hardware problem. You should probably return it as soon as possible.
Dec 19, 2008 | Sony VAIO® VGN-AR370N12 PC Notebook
Volume
The tv has a static sound and picture has vertical lines but is still visible. Heeeeeeelllllp. Thank you.
Jul 21, 2008 | Philips 19PR19 19" TV
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Apr 17, 2007 | Sony KP-53S65 53" Rear Projection...
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
