Question about Sylvania LC320SS9 32 in. LCD TV
Three black streaks on TV caused by what - Sylvania LC320SS9 32 in. LCD TV
What is causing black streak
Usually black streaks are caused by faulty rollers in the fuser assy. Depending on how many prints/copies you have on your current one it may be time to change it.
Feb 16, 2014 | Canon NP6221 Fuser Thermofuse
I have three black circles, and some color streaking at he bottom inch of my RCA, LCD tv
that is usually caused by cleaning the screen with windex the windex runs down the screen bewteen the screen and plastic frame and actually seeps inside between the screen layers. Eventually it may go away by itself if the circles are not too bad but in most cases the damage is permanent.It can also be an issue called screen delamination which there is no fix for.
Mar 02, 2012 | RCA Televison & Video
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Black streaks on LCD TV. The longer the TV is on
    Ur backlight video board is dying,replaced it to solved the problem.
    Dec 15, 2009 | Televison & Video
    Kirby G4 causes black streaking when shampooing carpet
    Replace the belt it is probably worn. You can get a replacement here:
    Kirby G4 Belt
    Dec 06, 2009 | Kirby G4 Bagged Upright Vacuum
    Light streaks and gray streaks and little contrast.
    Sounds like there are multiple problems on this machine. Dirty optics can cause light images, white streaks can be caused by dirty cortron wires(becareful when cleaning the wire or all the wires 3 usually, Q-tip can help) , not enough toner in the ink hopper, dirty cleaning blade in the drum modual. A bad heat roll can cause streaks also. Background with light images and black spots can be caused by competitive toner not working very good.
    Oct 15, 2009 | Canon PC-920 Black and White Copier
    Dell 3100cn Smudges on all color except black
    Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
    Feb 24, 2009 | Dell 3100cn Laser Printer
    Black streak on cloths?
    FRONT LOAD ,, BLACK STREAKS ARE USUALLY CAUSED BY RUBBER DOOR BOOT NOT CLEANED W/ FINGERS FEEL AROUND AND SEE WHAT YOU FIND ????????????
    Nov 28, 2008 | GE Energy Star WCVH6260F Front Load Washer
    Blank Streaks
    streaks are caused either by the toner, drum, lamp or fuser.
    If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
    open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
    Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
    Sylvania LC320SS9 32 in. LCD TV Logo
    Top Sylvania Televison & Video Experts
    matt martin
    matt martin
    Computer Repairing
    Computer Repairing
    Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
