Question about Precor 9.45 I Walking Belt
I use it for 30 min and turns off itself smells burnt
Which part I need
  • Precor Master
  • 914 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
This sounds like you are dealing with a worn deck and belt. If you apply wax periodically, you can prolong the life of these components.
Using your serial number, the link below will help you find the deck and belt needed for your model.
Precor Repair Parts for 9 45 9 45i Treadmills Consumer SPORTSMITH net
Posted on Nov 13, 2015
I walk for 30 min and turns off itself smells burnt
This sounds like you are dealing with a worn deck and belt. If you apply wax periodically, you can prolong the life of these components. Using your serial number, the link below will help you find the deck and belt needed for your model.
Apr 12, 2015 | Precor Exercise & Fitness
1996 Grand Marquis lets off gas smell through A/C vents after about 10 min with A/C on and more so when idle ???
Does the smell happen if you are running the hvac on just vent ?
The ac itself would not cause a smell unless the clutch on the compressor were slipping and you would probably hear that.
Its a sealed system just like your fridge at home.
So it could be something in the engine compartment that is coming thru the vent when the ac is on. The most common smell is a musty or mold smell from moisture inside the hvac.
Jul 20, 2013 | 1996 Mercury Grand Marquis
We moved the dryer in and turned it on. There was
Sounds like the motor shorted. Pull it apart and look for burnt wires and/or a burnt motor. The motor itself will smell burnt if it is.
Dec 13, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
I just bought a used Amana Dryer LEA30aw and when I turn it on it has a slight burnt smell. What could this be?
sometimes youll smell burning lint or dust.let it run 10-15 mins outlet temp should be no more than 160'.smell should go away after a couple of mins.if temp exceeds 160 may need tstat.please rate my solution
Dec 06, 2009 | Amana Dryers
It smells like burnt plastic after 30 min
is it new? how old is it? burnt plastic is the smell a bad motor produces. dont worry, i dont think it will cause a fire, but a fan motor on its way out will stink!
if its relatively new, return it. if not, get a new one!
Aug 05, 2009 | LG L1004R Air Conditioner
Fixed ac problem now smell gas inside vehicle
burnt or unburnt gas? if burnt gas smell look for bad manifold or manifold to pipe (donut) gasket.
if unburnt smell look for gas line leaks
Jul 28, 2009 | 1998 Ford Windstar
Yes the light is under the power cord. I unpluged and waited for the light to go away. I give it about 30 min then pluged it back in. that did not work. every thing else on the same power strip works. It...
Sounds like a power supply. Look for fuses on the motherboard that could be blown. Also, you may smell a distinct smell of burnt electronic devices when you smell near PS. Good indication it is fried.
Jun 23, 2009 | Gateway 838GM (RB838GM) PC Desktop
Burning smell
thermal switch is not working...upon reaching a certain temperature limit it should switch off then switch on again after a moment to maintain the set temperature..what happened here is that your thermal switch didn't switch off so the temperature continue to rise to the extent that the heating element burnt and smell like that..adjust the setting in such a way that it switches off after reaching the desired temperature..
Jun 18, 2009 | Rowenta Irons
New Sharp Aquos LC37X20E. After 30 mins turns itself off to standby and comes back on after 2-5mins (even though the automatic return to stanby has been set to "disable"). Eventually after...
According to Sharp it is a software problem. Engineer came, installed software update ,10 minute job.....TV worked fine for 1/2 day unfortunately: Then images turned black and white in all channels TV turned itself off, and stanby and OPC buttons started flashing. When TV came back on its own 10 mins later , screen had 2 large square staines superimposed in image (as if it was a burnt screen)...Engineer will be back next week...all quite sad really for a new TV.....will keep u posted
Jul 03, 2008 | Sharp Televison & Video
Precor 9.45 I Walking Belt Logo
101 people viewed this question
Top Precor Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Shehu Pro
Shehu Pro
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
