Question about Husqvarna Garden
My Husqvarna riding mower is leaking oil behind the oil filter how do I fix it
  • Kprime
    Kprime Apr 12, 2015
    Hi Darrell young, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Need Make/Model/Year/Engine Model/Transmission Model/Deck Size, and hours on meter if you have one. If you haven’t already done so, add a short description of the events preceding the beginning of the problem.
    Top Expert:
  • Husqvarna Master
  • 10,875 Answers
Replace the filter,or tighten filter
Posted on May 01, 2015
  • 81 Answers
SOURCE: oil leaking from air filter area of push mower and mower smoking
You have overfilled the oil tank. White smoke is only a hassle, not a serious problem. You have to empty some of the oil and change the gas. Clean the air filter if it is the spongy type with Dawn Dishwashing Liquid, rinsing and drying it well before reinstalling. The white smoke will stop soon as it is still in the gas that is in the carb. If the case is that you haven't filled it with oil prior to this smoke then you must be mowing on a hillside and the gas tank was on the lower side allowing oil to leak into the gas. Same solution.
Posted on Jun 24, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
  • 6468 Answers
SOURCE: husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Posted on Apr 30, 2012
SOURCE: Craftsman II mowre oil capacity and filter type
The outstanding Briggs opposed twin engines have an oil capacity of 1.5 qts. The recommended oil is 10w30 full synthetic and 50 hour change intervals. Some engines were equipped with an oil filter, if so, the capacity is 1.7 qts. fantastic engines, take care of it.
Posted on Aug 05, 2012
How do you check the hydulic oil on the mower
You didn't give the model number but from the manual I read it is sealed. "the transmission is maintenance free with no need for
level checks or oil changes. If a leak occurs, replace
the unit or contact your Husqvarna dealer"
http://www.husqvarna.com/ddoc/HUSO/HUSO2010_USen/HUSO2010_USen__115384327.pdf
Jul 21, 2014 | Husqvarna 26 Hp 54" Deck Zero Turn Riding...
Oil leaking around the oil filter, oil filter has been tightned
Did the old gasket from old filter stick to base and when you put a new filter on it now has two gaskets? I would remove filter and clean base thoroughly and check for additional gasket. After installing new filter I would clean the area well. Add oil, start unit and carefully check for leaks to pinpoint. Hope this helped. Happy wrenching!
Sep 08, 2013 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna riding mower, (Model: YTH2448) won't turn over
turn on device and wait for response inspect every component for malfunction
May 13, 2013 | Husqvarna Garden
Husqvarna YTH 180 transaxle fluid
If it is not leaking there should be no need to add oil, if it does not have an external resivoir you would fill throught the filler and leave a 1/4" air gap to allow for expansion.
Aug 10, 2012 | Husqvarna Garden
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut hydrostatic transmission slipping
first i would check the belt tension also check the belt for oil is so look for the cause of the leak the repair the leak and replace the belt
Jul 30, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Lost owners manuel and need to know what type of engine oil to use for a Husqvarna 25-HP V-Twin Hydrostatic 54" Garden tractor
if engine is briggs use briggs sae 30 oil also change out filter use briggs black std oil filter or yellow filter if els version
if engine is kohler use kohler 10w/ 30 oil and use kohler oil filter
if its honda use 20w/50 oil and use honda oil filter
if its kawasaki use 20w/50 and use kawasaki oil filter
cheers pauly 46
Mar 26, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
ENGINE OIL CHANGE QTY
Your owner's manual states: 51 Ounces W/Filter and 35 Ounces of Oil Without Filter. This info can be found under specifications.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2008/HOUS2008_532430577.pdf
Mar 23, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
I have a yth2246 riding mower. what type of oil should i use?
Typ of oil - best for this engine is SAE 5W-30 and company - maybe Castrol.
If you change oil with oil filter you need oil 64 oz if without oil filter - 60oz.
Mar 17, 2011 | Husqvarna 22 Hp 46" Deck Yard Tractor
Garden Logo
101 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
