Question about Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
The storage drawer is stuck - have tried using spatula to free up trays but they are still stuck. We can only open drawer about an inch.
    Problem Solver:
  • 12 Answers
Pull the range away from the wall and access drawer from the rear or try tilting it backwards with help.
Posted on May 08, 2015
LG washer detergent dispenser won't open The dryer is on top of washer
if you are patient, if you are lucky, you can take a very flexible tool like a frosting spatula and work it into the right hand side of the dispenser drawer and work it back and forth while moving the drawer in and out from its stuck position and maybe get it over the top of the softner tray and free the drawer. the top of the softner is popped up a bit and is catching on the top of the dispenser's enclosure top. about an inch or so in from the right. takes luck, skill and most of all patience. not easy but maybe less work than removing the dryer and going into the top of the washer. (if you get it out, then thoroughly clean everything up, then file down the front of the softner cup so it will not happen again--or throw away the softner cup and stop using softner) GOOD LUCK
Oct 20, 2016 | LG Washing Machines
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
I have a GE Adora front load washer and my detergent drawer is stuck shut. It won't open no more than an inch. Is there a way to remove it w/o breaking the drawer, in order to get the items out of it?
sounds like something is block the draw from open all the way.
Try using a metal coat hanger or a paint stir hand from Home depot the very long one.
slide along the open part of the door.
Apr 28, 2015 | GE Washing Machines
Dispenser drawer stuck closed
A common issue on older lg washers, since fixed with a redesign on newer ones. The immediate solution is to take washers top off and partially take dispenser tray apart to free it. The issue is the fabric dispenser is slightly ajar and catching on a lip of the dispenser top and jamming the tray. Thoroughly cleaning tray and all parts will fix but a more foolproof permanent solution involves filing down the leading edge of the fabric softener tub to a rounded edge so it will never happen again. Not easy, but doable. Two screws in back to take top off by sliding it back about two inches and lifting off. Good luck
Apr 02, 2015 | LG Washing Machines
How do I open the storage drawer without damaging it? Has become jammed by the contents.
if their is enough of a gap in the drawer , that allows you to see the object blocking it, then try using a spatula to push down on the item and move it back as I suspect that it is stuck on a small protrusion at the top of the drawer.
Nov 22, 2014 | Rangemaster Classic 110 (Dual Fuel) Dual...
MY BUTTON IS STUCK ON THE DVD-ROM TRAY. WHAT DO I DO?
if you look on the drawer for your dvd drive, you will see a little hole.If you push a pin in the hole the drawer will open.
Aug 20, 2012 | Computers & Internet
Cd tray tries to open butacts like its stuck
Take a Norwegian paper-clip.
Straighten one end.
Insert that end into the small hole in the faceplate of the CD-drive, until you feel resistance.
Push it another 1 centimeter (1/4 inch) against the resistance.
This will "unlock" the drawer.
Push the open/close button, to fully open the drawer.
Remove any CD disk.
May 09, 2011 | Computers & Internet
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
Jammed storage drawer
svineyardWelcome to fixya.
I'm Huuum and happy to assist you,
You said, Y inherited a GE Spectra XL44 in the home I recently bought so you don't know much about it. There is a pan stuck in the storage drawer and You can only open the drawer about an inch and a half before it jams.
You need two people.
One strong person to slide the range forward, so he can tilt the range far enough back, that you can access the drawer from the bottom and the pan will fall back inside the drawer as you pull the drawer forward and out enough for you to reach the pan and turn it around or what ever you need to do to get it out!
Bravo, I want to hear that you succeed!
Be careful not to hurt your self.
Bless You Huuum.
Please do not forget to leave a rating when you are done.!!!!!!!!
Aug 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Rangemaster Toledo 110 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
156 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
paulcarew
Mike Carew
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
