The rinse light is flashing and the machine will not wash or spin
  • tom cassidy
    tom cassidy Apr 12, 2015
    Hi Lesley Wright, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 12, 2015
Why does the lid lock light start flashing after the wash cycle and will not rinse or spin?
Lift lid, stick screwdriver into slot where lid latch-pin inserts and see if it goes into the cycle. If so, try adjusting position of latch.
Sep 01, 2014 | Washing Machines
Novotronic 1918 front load washing machine- not spinning 1st and 2nd rinse lights flashing
the flashing lights mean it's "disabled". You need a qualified repairman to service it further.
May 06, 2012 | Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Water is not draining and rinse light is flashing
top load fish pak washer wont dump or spin.constant beeps. rinse spin light and center wash light on .could dump valve be bad or how could line get clogged for dump
Nov 03, 2009 | Fisher and Paykel GWL11 Top Load Washer
The 3 buttons
button selection : To select an option press the button and you will see a light come on above the button. Press again to cancel and the light will go out. You cannot alter the options once the machine is running. Note : remember to cancel buttons after use!
As you look at the machine
Left hand button... Rinse Hold.. use this option to Help reduce creasing of delicate or synthetic fabrics by holding clothes in the final rinse water. The rinse hold light will flash to indicate that the programme is holding final rinse water. Complete the final spin by pressing the Rinse Hold button when light is flashing.
This is not available with Wool or Spin only programmes.
Middle Button.... Energy Save... use this option to save money and time on lightly soiled loads. This is not available with the Quick Wash, Rinse and Spin, or Spin Only programmes.
Right Hand Button .... Super Rinse... use this option for Large Wash loads and items for young children or people with sensitive skin. This option increases the water level for the first two rinses. This is not available with Cold Wash, Rinse and Spin or Spin Only programmes.
Copied from my Hotpoint FEW12 user instruction sheet.
Hope it helps.
Sue
Jul 31, 2008 | Hotpoint First Edition FEW12 Front Load...
HOTPOINT AQUARIUS WF 250 ON/OFF LIGHTS FLASHING
The lights are set off by the balance sensors.And if your balance sensors are  stopping    it from spinning than you first have to make sure the washer is level.You  could have bad Shocks and a bad electronic control board,.
May 05, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
