Will not start cycle or fill - Washing Machines
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 12, 2015
Water fills at a trickle during rinse cycle and NEVER fills up.
check urt water inlet valve and urt water pressure swttich
Sep 20, 2014 | GE Washing Machines
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
WATER ONLY FILLS 1ST TIME ON ANY CYCLE
Hi, After the first cycle, and after it drains/spins, does it start agitating when the next load of water is suppose to be filling?
Please let me know so I can assist you further. Sounds like the pressure hoe from the tub to the water level switch is plugged.
Thanks
Vic
May 17, 2009 | Maytag 24 in. MDB4100 Built-in Dishwasher
Washer just started on fill cycle to start and continued filling
you have a hose that came loose to the pressure switch or the tub or you have a bad pressure switch
or the fill cup is blocked
Apr 22, 2009 | GE WJSR2070B Top Load Washer
Kenmore 90 plus won't fill on regular orpermanent press cycle.
OK, Duh..... I guess there is about a 2 to 3 min. delay for the liquid soap dispenser to fill up and disperse the soap into the washer tub. After that short cycle is complete the fill cycle engages and fills at normal speed.
Mar 24, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Dishwasher will not run after filled with water
The float switch in the tank is bad,also if water only trickles in your fill valve is going bad which will not let it fill all the way to start wash cycle. Fill tub with pot of water to raise float, if wash cycle starts,replace fill valve,if not,replace float switch.
Jan 21, 2009 | Dishwashers
My top-loading Maytag starts to fill with water when I turn it on and then completely stops and doesn't do anything more.
it could have a problem with the pressure switch.
the water supposed to trigger the start of the wash cycle and turns off the filling cycle.
it is a single trow switch that disconnect the connection of water filling and connect the wash cycle on.
maybe it is disconnecting the filling cycle but would not connect the wash cycle.
tnx 4 using fixya,
drcool
Sep 07, 2008 | Maytag Washing Machines
Washer fill with water after final spin cycle
CHECK THE TIMER MODULE ,the one you pull and push to start and to stop ,that could be damaged , try different cycles , like DELICATES cycle , see what happens, hope it helps AJ
May 05, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
