Question about Sharp XEA106 XE-A106 Cash Register SHRXEA106 SHR XEA106
Why isn't it printing?
New print roller installed
Casio hr-100tm ink roller
Check to see whether a fragile plastic roller pin or retainer has broken off. Also, a piece may have fallen out when the old roller was removed.
Aug 30, 2012 | Casio "HR-100TM Two-Color Portable...
Orange light blinking, cleared paper jam, changed printer cartridge, won't print subsequent documents.
Double check all doors/ rollers for small pieces of paper stuck in the rollers. Sometimes just opening the door in question and closing will reset the paper jam sensors. Paper jams can be smaller than your pinky finger nail. So double check,
Comment if it still isn't working.
Oct 21, 2011 | HP Deskjet F335 All-In-One InkJet Printer
A3 paper jams up as it exists the fusser unit. This usually only happens after printing off three sheets. A4 paper works fine. Paper weight is 80 grams on A3 and A4 and the fusser is set to normal...
chances are the pickup rollers are worn and in need of replacement,these are located just above the tray inside the printer and are both easy to remove and widely available
May 18, 2011 | Office Equipment & Supplies
Replace cartridge on hplaserjet2300dn
Hello!
Thank you for your inquiry.
HP LaserJet 2300dn The HP LaserJet 2300dn printer is the same as the HP LaserJet 2300n printer, except that the printer comes with a built-in duplexer (for automatically printing on both sides of paper).
Here is a link to the user guide that will help help you with a lot of common problems including managing the print cartridge area on beginning on page 68. http://www.avss.ucsb.edu/download/hp2300man.pdf
If this is a new toner cartridge the installation instructions will be included inside the packaging including instructions on eco-sensitive means of disposal of old cartridge.
If this is your first time installation you will find it's very simple.
  • Turn the printer off.
  • Open the top cover.
  • If new - remove any orange tabs labeled remove 1st. If this is a replacement cartridge grab the old toner cartridge by the finger hold indentation and pull up.
CAUTION
To prevent damage to the print cartridge, do not expose it to light for
more than a few minutes.
Be careful not to touch the transfer roller (the black, rubber roller located
underneath the print cartridge). Skin oils on the roller can cause
print-quality problems.
  • Install the new print cartridge. It should slide easily down the guide slots on either side.
  • Close the top cover.
Note:
If the print cartridge is difficult to reinstall, make sure that the registration
plate has been flipped back down into position and that you have
pushed the print cartridge firmly in place.
  • Power the printer back on.
Hope this helps helps. Please keep us updated and remember to rate this answer.
Thanks for using FixYa,
TF
May 16, 2011 | HP LaserJet 2300dn Printer
How do you change the ribbon
Hi mkline519,
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
Jan 13, 2011 | Sharp EL-2192Rll Calculator
Imprime letras borrosas como si se le pasara la brocha.
Do you mean blurry, like toner isn baked, or ...
If yes, dispite the good conditions of fixing roller, you may want to replace bushings of fixing rollers too. Because they do not generate enough pressure.
Jun 30, 2010 | Canon PC170 Copier
Making a cracking noise from the fuser unit area
I'm assuming that the cracking noise occurs as the printed page is passing through the fuser?
Check your print settings to ensure that your paper stock is not set to heavy (card). This setting applies extra heat to the fuser to 'fuse' the text to the paper, which is what you want for card, but if you are printing normal stock, it will overheat the toner causing it to stick to the fuser roller on the way through and make a 'cracking' sound as the paper peels off the roller.
Whilst it is possible that there is a fault with the thermostat and the fuser heater is not switching off, this is rare. If you have been printing a number of pages at an incorrect paper stock setting you may need to clean baked text of the upper fuser roller, in which case, apply the following procedure.
After switching off the pirnter and it has had time to cool you may be able to clean the upper fuser roller with a rag moistened with a little methylated spirit, although you will not be able to rotate the roller fully without removing the fuser assembly from the printer. If the roller is physically damaged however, eg. scoured, cleaning will not resolve the problem, the roller will need to be replaced. This usually occurs after a long life, so it is generally best to install a new or reconditioned fuser (includes new rollers, top and bottom and new heat lamp).
Mar 19, 2010 | HP LaserJet 2420 Printer
I keep on getting burnt streaks on my prints and words from the print in the background its hideous
The heated roller in the fuser is what will transfer this to your page. After switching off the pirnter and it has had time to cool you may be able to clean it with a rag moistened with a little methylated spirit, although you will not be able to rotate the roller fully without removing the fuser assembly from the printer. If the roller is physically damaged, eg. scoured, cleaning will not resolve the problem, the roller will need to be replaced. This usually occurs after a long life, so it is generally best to install a new or reconditioned fuser (includes new rollers, top and bottom and new heat lamp).
Mar 16, 2010 | Office Equipment & Supplies
Epson aculaser c900
When printing, as thepaper is being transported up the printer, try pressing the right door panel of the printer firmly with your hand. If the colours are much improved then the printer requires a new Transfer roller.
1. Open the Right Door.
2. Remove the Transfer Roller while opening the shaft holder (white color) levers found at the left and right shaft ends of the Transfer Roller to unlock it. Lift out the roller.
Jan 21, 2009 | Epson Aculaser C1100 Printer
Sharp XEA106 XE-A106 Cash Register SHRXEA106 SHR XEA106 Logo
21 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
