Question about Canon PIXMA MP810 All-In-One InkJet Printer
It will not power on.
Tried to unplug and wait then nothing happened. Is there a service manual avalible so I can fix it?
Why is our LCD Samsung TV turning itself on and off by itself? The red light is also staying on.
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jan 24, 2015 | Samsung Televison & Video
How to fix the thermistor
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | LG WM-2077C Front Load Washer
TE error code problem How to fix the thermistor
Sep 27, 2011 | LG WM-2277HW Front Load Washer
For a while my tv had a problem. It did not turned on the first time I pushed the starting button. I had to wait and push the button twice and even thrice sometimes. But yesterday it did not turn on at...
As you have already tried reset, you can try connecting the TV to a different wall outlet and check. If the issue persists, the TV may require service.
Jul 12, 2010 | Televison & Video
No pwr to printer.plug fuse and cable ok. epsom dx5050
if their is no power ckeck your power outlet with any currnet meter to check the voltage is avalible to operate the printer is avalible change the plug cable and try again or try with any other cable avalible check the power switch of the cable if nothing happen better to contact your service center
Oct 18, 2009 | Epson Stylus DX5050 All-In-One InkJet...
Bose Lifestyle 48 not responding to remote or manual functions
I hd this same problem a couple of months ago. Disconttect all peripherals (any exterior amps, roommates) plug the power connector and wait for two minutes, while waiting connect the main system. try turning the LS 48 on. If this clears thing turn off the LS 48 and connect the peripheral one at a time testing with each new connection. Happy hunting.
Apr 21, 2009 | Bose Lifestyle 48 System
Cannon printer quit working suddenly.
Is it possible that the cord came unplugged from the transformer itself instead of the printer or wall plug?
A power outage shouldn't affect it, but a power surge can. Please use surge protection circuits on your computer equipment. It's so much cheaper than repairing or replacing them.
Take it from someone who learned the hard way....
You can try a printer reset. Turn the printer off, unplug the power and data cables from the machine. Wait at least ten minutes to allow the printer cache to be purged.(Canon's recommendation)
Then plug back in and turn on.
I hope this works for you! Good luck!
Apr 10, 2009 | Office Equipment & Supplies
Will not print
Most likely your print head is clogged, there are 2,00 some nozzle's in it. If the printer is not used for a moderate amount of time the ink can dry up and cause a clog in those nozzle's. You can try taking out ink carts, powering down with ink carts out. Unplug the power wait a few seconds with out power, power back on, wait for missing ink cart prompt, put ink carts back in close access door, wait for it to get done making noise then proceeed in doing a printhead clean from the main menu, or homecenter->?->maintenance. Then after that do a calibration, print a demo sheet to see if there is any improvment. The printhead clean pushes ink through the nozzles to try to clear clogs. The calibration scans those nozzles to see which are avalible to use, and makes sure that all the avalible nozzles are being used. If this does not fix the problem you most likely need a printhead but you will have to call kodak; as they are not avalible in stores. Also you can try updating your firmware from kodak home center, or www.kodak.com/go/downloads
Aug 22, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Washer filled with water then stopped
Same problem- quick fix- to release door anyway. Found the service manual online...First unplug power cord and remove bottom front panel. Reach underneath on the right side of the machine- there will be a white round plastic disk that you can pull downward to release the door lock and remove your wet clothes. I found a pen lodged inside which may have caused the 'glitch'. When I ran it again it did the same thing and locked at the same place. The service guy had to replace the door lock mechanism to permanently fix the problem.
Apr 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
69 people viewed this question
old marine
old marine
