Question about Garden
Where is the spark plug on a huskee heavy duty series 7 speed lawn tractor. It turns over but will not catch to start.
    Sergeant:
  • 462 Answers
Look under the front of the cab
Posted on Apr 23, 2015
  • 3 Answers
SOURCE: Huskee 25 hp lawn tractor with briggs & stratton motor wont start
Most all manufacturers have the Users Manuel available on line you will need the Make and Model to pick the correct one. Have you replaced the battery. It can show the correct voltage but have no cranking amps. I believe if the solenoid is trying to engage the Dead Man switches are closed. With the starter disconnected from all power sources do the teeth on the starter turn or are they locked up? If they refuse to move do you have an Auto Zone around or another parts store or electrical engine repair store that can test the starter. Make sure the mowing deck is not engaged while you are trying to start the engine. I hope these rudimentary suggestions help.
Posted on Jul 18, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
RonInFla
  • 86 Answers
SOURCE: Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Posted on Apr 10, 2010
SOURCE: My huskee lawn tractor will not turn over! The
The arm that engages the cutting blade tends to wiggle. Make sure it is pulled toward you (unengaged) before trying to start.
Posted on May 11, 2010
SOURCE: I don't know how to change the drive belt on a MTD
Go to mtdproducts.com then click on PDF Web Archive then click on "Public Site" then type in your model and serial numbers then down load the online manual then all you have to do is scroll down to page 25 and you're in business.
Posted on Aug 16, 2010
Huskee Lawn Tractor Manuals LT 4600
http://www.partstree.com/parts/mtd/mowers-lawn-garden-tractor/13aj771g031-huskee-lawn-tractor-2009-tractor-supply/
Apr 19, 2017 | Garden
Replaces battery and spark plugs in my huskee lawn tractor it cranks over but won't fire has full tank of gas and battery is charged what could be the problem?
No spark? Check out ignition coil. Make sure the fuel is turned on if you have an on line hose switch for that.
Mar 28, 2017 | HP Garden
Blades will not engage on huskee LT4200
Probably the PTO cable is either coroded up and struck or it is broken. You will need the 13W model number from serial tag to look-up as there is at least 2 different cable for this model series.
Feb 27, 2015 | Huskee Tractor Replacement Riding Lawn...
Huskee madel 13af673h131, won't crank
I guess you were sitting on the seat while trying to start the unit, so Try to apply power direct to the starter, if it turns over buy a solinoid. If it doesn't the starter may be bad. To check the engine: take out the spark plugs and try to turn over the engine from underneath by hand, using the pulley. This will tell if the engine is siezed up
Apr 10, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Huskee LT 4200 Won't Turn Over
Remove spark plug. Then try it. Sometimes filled with gas.
May 28, 2013 | Garden
Cub cadet 2554 GT just stalled and won't turn over?
check the fuses and cables safety switches
May 25, 2012 | Cub Cadet Garden
Jul 18, 2009 | Garden
50'' Huskee lawn tractor only turns in one direction
the brand huskee is now manufactured by MTD
Parts are available from tractor supply company at www.tractorsupply.com
there are pages of not very encouraging reviews about the huskee mower or about the tractor supply company but you can contact them to see what you can get
as for the problem , if it is a zero turn unit it may be a clutch arrangement needs adjustment
If you do not get any help from that company, you could ring around the mower repairs shops to get an idea as what could be wrong as the principle of operation will be the same .
also there are sites that have pdf versions of the workshop manual for huskee
May 20, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
