Question about Vornado Silver Swan Table Fan
MY FAN HAS A BROKEN BAND THAT GOES AROUND THE FAN TO HOLD IT TOGETHER. IS THIS PART STILL AVAILABLE AND WHAT IS THE COST?
    Genius:
  • Vornado Master
  • 1,617 Answers
You'll have to contact Vornado.
Posted on Apr 13, 2015
Drive pin does not retract
Easy to fix. Remove the head and pull out the cylinder. Look for black band around lower part of cylinder. This band (check band)should be placed around series of small holes. Replace if broken with any rubber that will hold up in oil or use a bunch of orings to fill space. Good luck.
Dec 14, 2013 | Porter Cable Air Tools & Compressors
My K & E 100' Favorite Wyteface tape will not rewind. This is such a beautiful device and I hate to trash it. There are no visible screws holding the shells together. The shells are leather with a steel...
most tapes have a single screw under the belt clip that holds it all together. You will have to pull it apart to replace the broken spring on the end of the tape.
Aug 09, 2013 | Measuring Tools & Sensors
The electric cord plastic jacket melted and burned through wire on one spot. Can the cord be replaced
I am currently attempting to do that myself. You need to separate the liner from the outside part. Using a pair of pliers, loosen the round nuts (found on the bottom) holding the unit together & separate. You'll find that the unit won't come completely apart because of the wiring. There is a heating band, held together by a spring, around the inner liner. Remove the spring to release the band. This should allow you to remove the inner liner & give you access to the wiring. At this point, you'll need to clip the appliance cord by the little wire nuts. The hardest part will be getting the cord out; there is a strain relief grommet that holds the cord in place and prevents it from being cut by the sheet metal where the cord goes through. I broke this strain relief on my crockpot and am currently looking for a replacement. Once I find a cord relief, I should be able to reconnect the wiring, the heating band and assemble the unit. Be careful not to cut yourself on the sheet metal!
Nov 23, 2011 | GE 106661 4.5-Quart
Hai I'm Prem here that my lc nuovo go sound around fan coolend area like very noisy and vibration thx
With the engine cold, check the fan blade assembly for cracks. Some blade assemblies have a large ring or band around the outside of the blade tips. If it is broken the fan becomes off-balance while spinning and will vibrate badly. Fan replacement will likely need to be done to cure this problem.
Jan 06, 2011 | Yamaha V-Max Motorcycles
My battery door is broken I have to put a rubber band around it to hold the batteries where can I find the battery door
Battery doors are almost impossible to find online. I'd contact Fuji by telephone to see if they retail themselves, if not, i'd try and use the broken battery door to somehow replace the elastic band.
Nov 22, 2010 | Fuji FinePix S5000 Digital Camera
Broke the flimsy support plastic ring - Need to order new one
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
Oct 27, 2009 | Minka Aire F602-BNCH Gyro? Fan
Lid switch assembly
go to www.searspartsdirect.com for a picture of this units lid switch.it doesnt show it very well, but it will give you an idea of how it goes back together.
what you need to do is put the lever around the switch first, then put the plastic box on the switch and arm. then carefully hold the assembly together and try to get it under the top and put the 2 screws back into the housing holes.
it sounds simple but i have done this before and its not easy. you just need to be careful to get the screws into the mounts correctly or it wont hold together to allow the switch to activate when the lid is closed.
by the way was there a reason you took the switch off??
maybe because it wont spin?
by the way this unit is not 30 years old, maybe 20 at the most.
the drive couplings are a weak spot for these and you may have a broken one. it wont spin or agitate but will drain if this is broken.
Jan 28, 2009 | Kenmore 22422 Top Load Washer
Beater keeps falling out. The plastic thing at the top of the beater inside the mixer needs to be replaced. Where can I get the part?
Sunbeam 2366 stand mixer -- Front view: mixer-0-small.JPG -- 0d345a3.jpg-- image of the "beater clip": mixer-1-small.JPG -- notice the wear on the plastic clip --8982711.jpg -- image of the "modified" beater: mixer-2-small.JPG - I took a paper clip an wound very tightly to the smallest diameter (notice it covers the entire section to prevent slippage) and then put one wrap around the "top knot" to increase diameter --d67ddea.jpg -- image of the back of the front cover: mixer-3-small.JPG - notice the broken clip at the top. I used a wide scrapper blade to separate the cover from the main body. 3297c2c.jpg----
Oct 16, 2008 | Sunbeam 2366 MixMaster Series Hand/Stand...
Put band back on
Timex Canada told me the only way to fix this is to send it in. In trying to fix mine, I notice it is actually held on be slotted lugs/keyways and the 'loops' around the buttons probably don't do very much of the holding. Tried hard but i could not force things to go back together properly - not I'm searching Internet for a fix too when I found your query.
May 13, 2007 | Timex Ironman 54281 Wrist Watch
Vornado Silver Swan Table Fan Logo
205 people viewed this question
Top Vornado Dryers Experts
Dusty Ryan
Level 1 Expert
Steve
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
