Question about Beldray Handheld Steam Cleaner, 1000 Watt, Purple
I cant llock my beldray hand held steam cleaner
The safety cap won't lock. I push down and turn but when I let it go it pops up again. What am I doing wrong?
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Why does my Beldray steam mop leave floors so wet
It probably has mineral deposits inside from the water. This build up of mineral deposits prevents the water from heating up to a high enough temperature. So instead of hot steam, you get hot water.
Jun 03, 2014 | Beldray Handheld Steam Cleaner, 1000 Watt,...
Refill water tank
With the unit unplugged push down the steam lever and hold while pushing down and turning the cap..
Dec 25, 2013 | Euro-Flex Monster 1200 Handheld Steam...
Cannot open water tank for beldray 5 in 1 steam cleaner
Its very hard to open the tank as it has a seal on to stop water and steam escaping hold it tight and twist anti clockwise
Nov 09, 2013 | Beldray Heating & Cooling
Shark steam cleaner model sc505 cap stuck
Dang everyone is looking to sell you stuff and not help. I'm having the same issue too. How did they tell you that you should have done that then? Everything I read says push down and turn.
Jul 28, 2012 | Euro-Pro Shark SC-505 Handheld Steam...
Can't remove the safety cap!! What do I do?
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Sep 06, 2010 | Euro-Pro Shark SC710L Handheld Steam...
Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Beldray Handheld Steam Cleaner, 1000 Watt, Purple Logo
423 people viewed this question
Top Beldray Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Beldray Heating and Cooling Expert? Answer questions, earn points and help others
