Question about Kurio 7" Tablet with 4GB Memory for Families and Kids
How can I reset my kurio? I have trying plugging it in to see if the battery was low, didn't work. I tried to push the little reset button in the back, didn't work. The model number is C14100/C14150. The screen shows a symbol that looks like a USB symbol, but the line under it goes from white to red. It will not turn on. Can you help ?
Why won't my Kurio 4s charge?
Hi, quite a few things could be the problem, 1, the battery has died....which can be revived with the proper machine, 2. depending on age, it needs to be replaced, 3. your charging port is faulty and needs to be replaced, 4. the wall plug you use can also be worn out and does not make proper contact.....I would suggest that u rather hand it in to a bona fide technician.....
Jul 23, 2014 | Kurio Touch 4S Handheld
Why is my kurio touchscreen not working?
If there is no power button or it does not work pull the battery and wait a minute before you put it back in.
Jul 23, 2014 | Techno Source Kurio Kids Tablet With...
Power button wont work only if i plug it into the charger
honestly idk what to tell you....I never fixed the kurio I just sent for a new one under warranty. maybe try holding the power and volume button on and off....it might work it worked for my kindle but its not the same device
Mar 27, 2014 | Kurio Touch 4S Handheld
Kurio kids tablet is froze
Kurio won't come off blank screen, i've used the reset button, and the power with volume+ button and it's still the little kurio guy making the smiley face. i took the cover off, it's not hot. Any other suggestions as to re-boot it?
Nov 12, 2012 | Techno Source Kurio Kids Tablet With...
Kurio kids tablet won't start up
I fixed mine like this, unfortunately you will lose all your data on the system.
1) Whilst holding down the Power button, hold down the Volume+ button for about 10 seconds and let go.
The table should boot into a screen with an Android with a open chest and a danger sign on top.
2) Press the Volume+ button, and the recovery menu will appear.
3) Press the Volume- button, to move to "Wipe data/Factory Reset" and press the Power button to select that option.
4) Press the Volume- button to move to "yes" and press the Power button to accept.
Now the system will wipe the data and factory reset the tablet.
5) When it returns to the menu, make sure it is on "Reboot system now" and then press the Power button.
The tablet will now reboot and should load.
Aug 25, 2012 | Techno Source Kurio Kids Tablet With...
T20 low battery and no recharging
this is problem with your hardware.......
Jun 20, 2009 | iRiver T20 MP3 Player
My flip video camera froze.it wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
AVIC-N2 stopped working and wont stop flashing PLEASE HELP!
Sound like the ribbon cable because before breaking off completely the vibration of the engine can cause current to fade in and out(open and close circuit).
Nov 19, 2007 | Pioneer AVIC-N2 Car DVD Player
Kurio 7" Tablet with 4GB Memory for Families and Kids Logo
589 people viewed this question
Top Kurio Home Experts
thinksewfast
 Mikey
Mikey
Mister Danger
Are you a Kurio Home Expert? Answer questions, earn points and help others
