Question about Cuisinart CBC-00 Coffee Maker - 12 Cup Capacity, Advanced Brewing Tech
Won't brew the amount of water, put in 12 cups water get 4 cups coffee.
Changed charcoal filter.
    Top Expert:
  • Cuisinart Master
  • 51,191 Answers
Their measurements are for 6 oz or less cups not 4/ 12 oz mugs
Posted on Apr 12, 2015
I put in 6 cups of water and only 5 cups brew. It
The amount of water you put in the carafe isn't the same amount you'll get out of the coffee maker, as some of the water is normally lost as steam vapor during the brewing process.
I would also look at the water level gauge inside the reservoir or on the sight gauge to make sure I have added the right amount to make the amount of brewed coffee I want.
As to the filter pre-soaking issue, it shouldn't matter since you likely made several pots since then and the filter has likely expelled any residue already. I would run a full pot of just water with a filter in the basket, just to see if you're getting a full carafe after brewing, making sure you have a full reservour to begin with.
As to the grind of the coffee, I find that a medium coarse is best for all but expresso coffee. However, you might want to experiment with your grind settings until you find the setting that makes the coffee to your likeing and taste. Coffee is all about what you like to drink, so take some time to find what you enjoy.
I use a high-end filter for all my drinking and coffee brewing water to get the best possible taste as it does make a difference.
My nieighbors have the same coffee machine and use the same coffee brand, etc., but don't filter their water. They've noticed the difference and always comment that they need to get a filter for their water.
When I run white vinegar thru my machine, I always run at least two (2) full pots of plain water thru the unit before I start making coffee again, to rid the reservoir of any vinegar residue.
Hope you find this helpful and best regards!
Aug 06, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The...
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Jul 18, 2009 | Cuisinart DCC-1200 Coffee Maker
After taking out the filter basket and all the moveable parts, how do you clean the coffee maker itself?
You actually have to put the parts back in place (except the charcoal water filter and any paper filter you may or may not be using), pour in 2 cups distilled white vinegar and two cups water, and brew the vinegar/water solution just like it was coffee. Vinegar is very acrid, so you will then need to brew plain water to flush out the vinegar. Now, you can put everything back in place, and you are good to go. Remember - if one part is out of place, your coffee maker may beep at you incessantly.
-Tha Mp3 Doctor (also loves Cuisinart)
Feb 21, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Cusinart DGB 550BK coffee maker not working properly
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 12, 2009 | Cuisinart Coffeemakers
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Coffee doesn't brew full pot
-Tha Mp3 Doctor
Dec 28, 2008 | Cuisinart DGB-600BC 10-Cup Coffee Maker
What is the water filter for. and where could I purchase such
The charcoal water filters improve the taste of the coffee, although they are definitely optional. You can get replacement filters at Bed, Bath & Beyond; Williams-Sonoma; and sometimes Lowe's.
Dec 22, 2008 | Cuisinart Brew Central 12-cup Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart CBC-00 Coffee Maker - 12 Cup Capacity, Advanced Brewing Tech Logo
390 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
