Question about Kurio 7S Tablet
I am trying to turn it on, but I have a symbol that looks like the usb symbol and the line underneath goes from white to red. It will not turn on. How can I reset it?
How do i unlock my nexus 7 when its on the screen with android robot laying on its back?
Android robot laying down with a red triangle having an ...
https://androidforums.com > Forums > Featured Forums > Android Lounge
Mar 24, 2013 - 14 posts - ‎7 authors
Whenever i try to turn my android tablet on it displays android robot laying ... an exclaimation mark in a red triangle and dont let me proceed to its desktop . ... and holding it until it turns off and then turn it back on can revive it, ... no command error ' Android Forums
19 Jun 2014
HELP-Tried Recovery Reboot, Red Triangle w ...
15 Jan 2012
More results from androidforums.com
SOLVED: android guy on his back - Nabi Jr - iFixit
https://www.ifixit.com/Answers/View/349279/android+guy+on+his+back Oct 31, 2016 - my android guy on the screen is laying on his back with the stomache door ... Android recovery mode" and a few seconds later an Android robot ...
How to Fix The Dead Android and Red Triangle Error Symbol - YouTube
? 1:44
https://www.youtube.com/watch?v=58EPvbwPbe0
Oct 5, 2016 - Uploaded by Gauging Gadgets
Meaning of Green Android laying down and a red triangle with an exclamation point inside it: •If there is ... All ...
How to Fix The Dead Android and Red Triangle Error Symbol Android Recovery...
Jul 07, 2017 | Tablets & eReaders
Why did screen turn white?
probably a connection problem with the board inside,below is a link of how it could possibly be fixed
Android Tablet White Screen fix
White screen and lines on tablet repair no video Fix it Fik
Jan 30, 2016 | Chromo Inc Chromo AAAAAAAA White 4gb 7"...
What does a battery symbol with a red line mean. Won't turn on.
More than likely it means a dead battery. If it does not recharge, you will have to replace the battery with a new one.
Aug 14, 2015 | Amazon Kindle Fire HD 8.9"
How do I get my tablet to turn on
It sounds like it may not be fully charging.
If the port on the tablet is loose/damaged or the cable/charger is failing, then the tablet may not be charging even though its plugged in.
If you can, try a different cable.
Make sure the charger is the correct one for the tablet! Some tablets require more electrical current then a computer's USB port provides. Same thing applies if you are using a 'phone' charger with the tablet, might not be enough current.
Most USB ports/chargers output about 5 volts DC (direct current), but they can vary in the amount of Amps (A) or mili-Amps (mA) they produce.
FYI - the symbol used to represent Direct Current is straight horizontal line with a dashed horizontal line directly under it.
Most computer USB ports only produce 500mA.
Most phone chargers only produce 1A.
Many tablets require 2.1A or 2.4A to properly charge.
Check with your tablet manufacturer to find out what your specific make/model requires and the look closely at the charger you are using to see what the OUTPUT is ... e.g. 5.2V 2.4A
Mar 29, 2015 | Lenovo S5000 7" Android 1GB 16GB
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
Mar 28, 2015 | Tablets & eReaders
I already asked the question and then had to get off the computer. The question was how do I stay on the WiFi internet through netgear router. When the WiFi symbol shows I am conneted if I go too Chro
Need to know your signal strength and if you're connected with proper credentials. If the wifi signal is weak, the computer may disconnect to look for a stronger signal. Sometimes ipv6 is the culprit on older computers too. Disable that and use ipv4 only. There are multiple reasons for dropped internet so the more info about your system and the conditions under which the internet is dropped will help in diagnosing the problem without sending you on a wild goose chase.
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
How do I access the WiFi Internet Connection With Tablet
to get access to the wifi network, you need to do the following things:-
1. go to settings
2. open wifi option
3. turn on wifi
4. select the wifi network you want to connect.
5.it will ask for the password, insert the password and enjoy.
Hope you get your problem solved. Thanks
Nextbook problems
I have a next book and on it has a app called HDMI switch well that keeps coming on and when it comes on my screen goes black and then it will have white lines running threw it or the screen jumps with white lines on it
Jan 10, 2014 | Tablets & eReaders
Turn tablet on, then it says powering off right away.
That would be the charger or the usb port that charger goes into. the red ! battery is saying the battery is dead
Apr 06, 2013 | Google Nexus 7
Kurio 7S Tablet Logo
Top Kurio Tablets & eReaders Experts
ray gallant
Outback Jack
Outback Jack
Are you a Kurio Tablet and eReader Expert? Answer questions, earn points and help others
