Question about GE Televison & Video
How do I do an automatic code search on a ge unigersal remote control model 24993 - v4
  • 111 Answers
1 manually turn on device(TV, VCR,ect. Be sure batteries are good in remote.
2 press and hold the CODE SEARCH button until the red indicator stays on,then release Code search button.
3 press and release mode button (TV, VCR, ect) the red indicator blinks,then stays lit.
4 press channel up( up to 300 times) until device changes channel. The red indicator blinks,then stays lit.
5 Press the Mute button release to lock in code
Tips if you go pass the code use channeldown when channel change hit the mute button and release it to install code.
Posted on Jun 28, 2015
1Guru
  • 61 Answers
SOURCE: codes for daewoo tv, ge remote model 24912
Codes for Daewoo are: 0451, or 0092
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Posted on Dec 14, 2008
  • 1274 Answers
SOURCE: codes search for a radioshack 15-2147 remote
Here are the codes...1447,0047,0051,0178,1347,1917,1147,1907,1922,1919,.....To program.. Turn the TV on, make sure you have fresh batteries in the remote,and installed correct, Press and hold down the P button until the LED blinks twice, enter one of the four digit codes, the LED will blink twice,it not, repeat the steps using a different code..hope this was helpful...
Posted on May 30, 2010
SOURCE: tengo un control remoto universal
tengo un control universal GE 24993 y nesecito el codigo para un dvd philips
Posted on May 21, 2011
gopakumarg43
  • 74243 Answers
SOURCE: Cual es el codigo para programar lcd samsung con control remoto universal marca GE modelo 24993-3?
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Posted on Jul 30, 2012
gopakumarg43
  • 74243 Answers
SOURCE: need codes for a GE 24993 4-DEVICE UNIVERSAL REMOTE
Codes are: [0414 0839
Posted on Aug 04, 2012
Model 24993. What is code for Digital Stream Tech converter box?
You can use the CODE SEARCH feature of your remote to find something that may control some or all functions of the box. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Jan 25, 2016 | GE Televison & Video
I have a digital research flat screen tv.how do I program my ge universal remote model 24993-v4
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 12, 2015 | GE Televison & Video
I need instructions to do an auto code search for ge model 24993-v4 remote control
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Samsung tv codes
If your GE remote control is programmable, you can use its "code search" feature to finbd a code that will control some or all features of your Samsung TV. If your search is unsuccessful, there be no suitable code available.
Jul 28, 2014 | GE 24993 Remote Control
I need a code for a Phillips tv with the GE 24993 remote
You can look up the code here: http://www.jascoproducts.com/support/universal-remote-codes.asp
Sep 20, 2011 | GE 24993 Remote Control
I need the code of my controller GE 24993 to program my TV RCA
Hello
Setup codes for RCA TV with GE remote control are:
000 003 004 005 007 009 011 015 048
082 092 094 096 098 101 102 103 107
113 125 129 167 179 187 188 191 194
OK.
Aug 02, 2011 | GE 24993 Remote Control
Televison & Video Logo
62 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
