Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
My spa is at 89 and its set for 104 and the pump will no cut on whats the problem
  • Dream Maker ... Master
  • 1,631 Answers
Are you saying that it stops at 89°? It will not go any higher, even though you have the set temperature at 104°?
If that is what you are stating, then you probably have a bad temperature sensor.
Posted on Apr 15, 2015
My spa is at 89 and its set for 104 and the pump will not cut on what is the problem
You may be in economy mode. Economy only heats the water during a programmed filter cycle. You want it to be in standard mode which turns on the hot tub once the water is 2 degrees below the desired temperature. There should be a mode or program button on your topside. One some systems you'll have to hit prog/mode button then the temp up button to change the mode. There is also a sleep mode. Never used it not sure what it's for.
Apr 12, 2015 | Dream Maker Spas Dream Maker Ez Spa Hot...
Spa was below temp, now it heats and won't shut off.
Is your spa overheating, heating up past 104 degrees?
If so, you have a contactor (or relay) stuck shut and the spa should go into OH at 108 degrees.
d
If your hot tub is only heating to 104 or what ever temp you have it set at and the motor runs 24 hours a day there are a couple of things you'll want to check.
First, make sure that you do not have the pump set to run 24 hours a day.
Second, you'll want to see if the pump icon is lit up on the control panel. You will want to check to see if the icon is on while the spa is supposed to be resting. During filter cycles the icon will be lit. If you are not in a filter cycle and the pump is on while the icon light is off, you have a stuck contactor (relay). The relays can be found online for less then a couple of dollars.
If you have any more questions feel free to ask.
Feb 23, 2015 | Dream Maker Spas Dream Maker Spa - X500...
Spa warms up to 104 then down to 82. when temperature drops unable to run jets
not sure of the make and model here but sounds to me if you have a heater that "runs away" intermittantly and safety cuts it off this dissallows the pump from running also , carefull temperature monitoring can help you "SEE" this occur and develop a plan to affect a repair on part needed
off hand id say two parts to look at (water temp sensor) and power relay to heater coil for this problem
Nov 04, 2014 | Pool & Spa
SPA WILL NOT HEAT PAST 94 DEGREES. i HAVE IT SET TO 103 AND IT HAS NOT MOVED PAST 94 DEGREES FOR OVER 1 HOUR EXACTLY WHAT BUTTONS SHOULD BE LIT ? IN OTHER WORDS IS THE AIR BLOWER LIGHT SUPPOSED TO BE...
if hook up to the firemans switch turn heater all the way to 104 degrees if using 4 pin connector for aqua link to heater set spa temp to 104 and make sure on aqualink spa heat is enabled and 104 degrees
Nov 30, 2010 | Jandy Aqualink Rs4 One Touch Control...
I would like to turn the temperature up higher than the 104. Otherwise, it is too cold, in the snow. Is this possible?
Temperature above 104 is extremely dangerous ...Please dont do this. If it is possible (the manufacturer probably set this limit for health and legal reasons) and you insist, you should proceed ONLY UNDER THE DIRECTION OF A MEDICAL DOCTOR trained in this area.
Oct 31, 2010 | Qca Spas Cypress Spa
HI I have my hot tub at 104 but it will only heat up to about 80 degrees. what is my problem
If its set at 104, but only heats to around 80 degrees, then your heater is not working. Either the heating element is bad, or the pressure switch is not closing. The reason why the water heats up to 80 degrees, is from the friction caused by the mechanical shaft seal when the pump is running. Either way, you should really have it checked by a qualified spa technician. It is not something that the average spa owner can normally repair themselves. Sorry.
Sep 27, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Minimax pool heater cuts out at 91 degrees when remotely set for
Turn the temp set knobs on the front of the heater all the way up do both pool & spa temp.
If that doesn't help flip the selector switch on the front of the heater the pool temp. This switch doesn't control what heats up Pool or spa it just selects the heater on and which thermistat to use
May 23, 2009 | Pentair Minimax Ch 400,000 Btu Propane...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
296 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
Ian Kime
Ian Kime
john h
The Cover Guy
The Cover Guy
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
