Question about Kenmore Washing Machines
Kenmore 700 series washer won't fill with cold water
  • Kenmore Master
  • 2,963 Answers
Cold water supply valve on? Otherwise, you may have a problem with the washer electric solenoid fill valve.
Posted on Apr 12, 2015
aborcass
  • 2651 Answers
SOURCE: Kenmore washer: no cold water
easy way for me to determine problem is reverse the hoses on the machine still no cold??? should be no hot now!! in which case you have a bad water valve no cleaning need to replace
Posted on Mar 02, 2008
Illeagle
  • 525 Answers
SOURCE: washer does not fill
Firstly, check to see that your water temperature is selected properly. Next, check to confirm water supply to the washer is adequate, both HOT and COLD. If confirmed, try replacing the fill valve.
Posted on May 27, 2008
  • 91 Answers
SOURCE: slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Posted on Jan 04, 2009
  • 234 Answers
SOURCE: Kenmore washer won't stop filling w/ water
The problem is most likely the water level switch. This would be the case if the water is able to be turned off with the dial on the washer and not running all the time.
If it is running all the time and you have to turn it off at the water line valve, then the problem is a stuck water fill valve.
If you need more help, post a comment.
You can find information on the parts at partselect.com.
You can buy parts from them or find them locally if you want.
Thanks,
Tim
Posted on Jun 16, 2009
SOURCE: Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Posted on Jul 04, 2009
Kenmore series 700 won't fill with water just humms lid locks but add garner light stays on any help would be appreciated thank you
remove the screen from the supply hose and clean it... it is possibly clogged from mineral deposits. Try an experiment and fill the washer with a bucket and see if the light goes out. (I am willing to bet, it does, so the issue is the hose supply in the cold water side. Replace the hose, if you need to... Ace Hardware is best.)
Sep 02, 2017 | Kenmore Washing Machines
Kenmore 90 Plus Series washer washer takes forever
is the cold water all the way on?
if so, the first thing to do would be to check the screens in the cold water fill hose and the screen in the cold side of the water valve on the back of the machine. if that is not the problem then replace the water valve.
(turn the water off before taking the hose loose)
Jun 16, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washer 90 series will not fill up with water
You can shut off the water, then remove the hoses to see if the screens on the fill valve are gunked up. This is much easier to do than to replace the valve. I think you'll have sucess on that route :)
Aug 09, 2009 | Kenmore Washing Machines
Kenmore 90 Series Washer : cold water fills at just a trickle:
your hot water goes through the water heater so contaminates settle in the heater. the cold does not, there is a screen inside the fill valve where the hose hooks to the valve on the machine. if this in not plugged then the fill valve will have to be replaced. because of the build up of contaminates..
Jul 08, 2009 | Kenmore Washing Machines
I have a kenmore washer 700 series. Water is
Yes its true that this washer not worth repair.... Better you can go for a new washer..
I have a question - is there any error code on the display control?
thanks
Jul 07, 2009 | Kenmore Washing Machines
Kenmore 90 series Water pressure turning up and down
it will switch from hot to cold and back and forth trying to regulate the temp. You probrbly have more pressure in your cold water line than your hot or vise versa. This will cause it to seem to pulse. Dave www.washermd.com
Jan 12, 2009 | Kenmore 24032\24036 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore series 70 top load washer - cold water fill very slowly.
The screens in the line are clogged. There is usually a screen in the washer hose at the point where it is connected to the faucet as well as one by the water inlet valve. NEVER REMOVE THE SCREEN BY THE WATER VALVE. As for the one in the cold water fill hose, that can be cleaned or replaced.
Dec 13, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series top loader the washer will not fill with cold water only hot water
Yes patrick you can try removing the cold hose from the washer, look inside the valve for a metal screen. If it has sediment blocking it remove screen, clean it and reinstall. If still no water replace inlet valve.
Dec 01, 2007 | Kenmore 24902 Top Load Washer
Washing Machines Logo
127 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
