Question about Mtd Garden
Hi, my question is how to connect the battery charger of the MTD mini rider 76E.Thank you.
It seems the model i bought doesn't come with plate and connector for charger plugin, but it includes the charger. is this normal?
    Problem Solver:
  • 18 Answers
You should be able to connect the charger directly to the battery and plug the charger in to an outlet. Black to negative, Red to positive...
Posted on Apr 29, 2016
Testimonial: "Thanks. The charger had a standard plug but not separated positive-negative terminal. Anyway the store replaced the battery for free."
3 Suggested Answers
jrw4u
  • 62 Answers
SOURCE: I bought a mtd yard machine at a yard sale today.
well its more than likely got to much oil in it or the oil needs to be replaced usually when one smokes thats what it is or some one has glipped it on its top and all the oil is at the top of the engine if its that it will stop sooner or later
Posted on May 01, 2009
SOURCE: battery charger for craftman electric lawn mower
junked the charger connectors and replaced the connectors with better type of connectors that an old man can get a hold of to take apart to connect the charger when needed very poor design for elderly use.
Posted on Jun 15, 2009
Battery are not charging, charger is working and have new battery but not charging
hi Ed, okay a very common problem, firstly convince your self the batteries and the charger are okay,
Make sure the charger plug located on the scooter is a good connection
Check the battery terminals...
If you give me more details about the model shop-rider, I can give you a more precise details about where to look..
Regards
Rob
Dec 03, 2015 | Shoprider Health & Beauty
Batteries won't charge
Hi. Sounds like there is a faulty connection somewhere between the charger and the batteries. Are the batteries connected correctly. The charger uses the voltage level in the batteries to regulate itself. If there is a faulty connection, then the charge will not operate. Use a multi-meter to check if the batteries are connected correctly. There should be 24 to 26 volts across both batteries.
This fault can also be caused by a faulty charger socket. Check for any signs of melting or heat damage. There might also be a disconnected wire in the plug on the charger itself.Good luck. Neil.
May 29, 2010 | Drive Medical BLUE 3 Wheel Compact Mini...
Mower will not start, battery cgarged up but onlhy
Check all the wiring connections on the starting system. Start at the battery. Both posts. Then, check where the ground goes to the body of the tractor. Make sure it's not rusty and making a good connection. Check the wire from the battery to the solenoid. If worse comes to worse, you can take a jumper cable and go from the battery + side and jump right to the starter post where an electrical cable connects. This will let the engine turn over, but make sure you have the mower in neutral and brakes set, with blades OFF!
Jan 28, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
I need a battery charger and instruction book for jvc mini gr-d27
Have you tried the JVC website? They have accessories along with chargers.
Rob
Feb 06, 2009 | JVC GR-D270 Mini DV Digital Camcorder
Garden Logo
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
