Question about Everstar Portable Air Conditioner Everstar
I have a everstar port..when i turn it on it will cool for about 10 mins then turn fan on low..run for a bit then compressor shuts down and the fan comes back on high and blows heat at you
Its a Mpk 10cr 1
2 Suggested Answers
  • 44293 Answers
SOURCE: Everstar MPK-10CR compressor keeps running after power off, on remote. Display blanks. Only shuts off when O/L @ wall plug tripped.
call in an electrician as there is a problem in the circuit allowing power from a neutral line and bypassing the switch
Posted on Jul 01, 2016
Ac compressor runs 5 min shuts off then restarts 10 minutes later for another 5 min fan runs ok
Shutting down on safety. It's likely a pressure switch, possibly low pressure if fan is running.
May 24, 2017 | Heating & Cooling
Why is my air conditioner unit only running properly on cool days? when its hot out it only runs about 5 mins at a time then shuts off to fan and dont come back on for another 20 mins.
Do you hear a click sound as the compressor shuts down? If so that is the clixon (heat sensitive circuit breaker) that is opening and shutting down the compressor when it overheats. You have not had the AC filled with refrigerant so overfilling the unit cannot be an issue.
And if it is not overfilled overheating is caused by excessive current going into the motor which could indicate a problem with the motor windings..
OR, If the thermostat is faulty it could be prematurely shutting down the compressor. If you jump (bypass) the therm and unit does not shut off then you have found the culprit.
Sep 08, 2015 | Heating & Cooling
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
2 yr. old. worked great. Then started shuting down self changing setting to low. shortly after, shuts down after 3 min. no water collection, unit is hot. Took apart. Cleaned everything inside, and filter....
Robinson, it really sounds like the compressor is overheating. This may be caused by a low refrigerant gas in the compressor. Or the compressor's oil has leaked down. But, if you took the unit apart to clean it, I would think that you would have noticed an oily residue. If it is the compressor (other than needing to be recharged) it would cost almost as much to replace it, as it would be to buy a new unit.
At least with a new one, you'd have a one year warranty and more, if you purchase an extended warranty.
Hope this helped you.
Jun 02, 2011 | Dehumidifiers
Kenmore 12,000 BTU Room Air Conditioner ENERGY STAR
How many Square Feet is the ac rated for?How large of room are you trying to cool??
May 27, 2010 | Heating & Cooling
Radiator fan runs after car is turned off. Only occurs when A/C is run for more than 10-15 min. Shuts off after a few minutes, but is concerning.
That is nothing to worry about the fan remains running after the vehicle shuts off in order for the engine to cool down. Once the motor cools down sensors trigger the fan to shut it off.
Sep 10, 2009 | 2004 Ford Focus
Compressor and fan not working
have you check the freon because if freon is low it will shut off on low pressure. And what kind of Stat do you have is the Stat telling it to stop. try hot wiring it at the stat.you can also just push the contact down Manually and make sure fan come on to. check is fan turning fast enough and is it turning the right way.are the coils clogged.hope this helps
Jul 07, 2009 | Heating & Cooling
Admiral LTF2112ARW cooling problems
First I would make sure the compressor is running.
Unplug the Ref. for about 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the Ref to tell the difference between the compressor fan and the compressor. If the compressor clicks and doesn't run then the relay on the compressor should be replaced. If it runs then it is probably low on coolant.
Dec 13, 2008 | Admiral 26 cu. ft. Side-By-Side...
Fan runs, shuts down on cool
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
Jul 17, 2008 | Dometic Rooftop RV Air Conditioner
Everstar Portable Air Conditioner Everstar Logo
75 people viewed this question
Top Everstar Heating & Cooling Experts
tractorman44
tractorman44
jack morton
Are you an Everstar Heating and Cooling Expert? Answer questions, earn points and help others
