Question about Kartell Ero S Chair Aluminum Base - Crystal
Can I purchase the clear plastic seal that sits between the top of the aluminum base and bottom of the chair
  • 2,963 Answers
Owner's manual no manual? Try MFG website or email their customer service, or try Ebay
Posted on Apr 12, 2015
Bunn coffee pot leaking bottom
The leak is most likely between the water reservoir and the tank. Bunn uses a soft silicone seal for that connection that gets compressed over time and starts to leak water whenever you make a pot of coffee.
It's planned obsolescence. Bunn won't sell you a new seal. So you have to improvise. But it's simple enough to do.
Remove the top cover and the plastic water reservoir right below it. Don't tamper with the little valve that opens when you close the lid.
Look for the seal. It could be stuck to the bottom of the reservoir, or sitting loosely on top of the metal tank. Make sure to preserve its top-to-bottom orientation (don't put it back in upside down).
Apply a narrow bead of clear silicone into the grooved side of the seal. Press the seal gently onto the reservoir, then apply a thin layer to the smooth side.
Re-install the reservoir and reassemble the unit.
Oct 02, 2014 | Bunn Coffee Makers & Espresso Machines
How to fix a leak on a bunn NHBX coffee maker
Aug 09, 2014 | Bunn NHB Coffee Maker
What materials are beach chairs made of?
Most beach chairs are made from plastic, while other chairs are made of wood and metal. Plastic chairs are the most common because they last for a long time and can be washed pretty easily. Moreover, they dry up quickly. Aluminum chairs are also light and portable, but they tend to bend. Wooden chairs look nice, but they tend to be heavier than regular plastic beach chairs.
Aug 19, 2012 | Garden
How do I keep my dining room chairs from scraping my parquet floors?
You have a few options to keep you chairs form scrappingyour floor. Although not necessarily astaticallypleasing, you could put an area rug under your table and chairs. The most popular remedy is little plasticdiscs that use self-adhesive to attach to the legs of the chair. You can also get "fabric backed coaster cups"which are little bits of fabric that are attached to the legs. The other option is clear plastic mats thatthe chairs sit on top of (like for swivel chairs in offices.)
May 29, 2012 | Furniture
Sealed radiator on top - radiator hose has blown off twice - not overheating HELP
aluminum radiator
plastic top and base seal
tanks held in with crimps on aluminum radiator
find a local radiator shop to replace top seal and top plastic part
of that radiator
not as expensive as a new radiator
replace the thermostat
pressure is too much on that crack for any diy repair product
pop off hose at the wrong time =cook the motor
Apr 29, 2017 | 1996 Isuzu Trooper
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
My washer is leaking from the bottom as if there is a seal that is worn out. what do I do How do I get the tub out to replace the seal
If this is a front loading machine. The bolts on the drum case have most likely loosened. Remove the rear cover to access the bolts. After tighten the bolts run the machine to make sure this was the problem.
Jul 09, 2009 | Frigidaire FEX831CS Top Load Stacked...
Problem with staemcleaner
Check the bottom of the solution bottle to make sure that the seal is on the valve and not in the hole that it sits in.
Check to make sure that the seal that sits on top of the clear window, it seals the opening between the top and the tank. Also is the filter clean, the one on the bottom of the lid?
Sep 19, 2007 | Bissell 7950 ProHeat Upright Wet/Dry...
Kartell Ero S Chair Aluminum Base - Crystal Logo
893 people viewed this question
Top Kartell Event Planning & Celebration Experts
DAVE PARTA
Level 1 Expert
samiya_jahan
Level 1 Expert
Are you a Kartell Event Planning and Celebration Expert? Answer questions, earn points and help others
