Question about Bosch Washing Machines
My bosch classix dryer is saying container is full but its not and machine keeps turning off. Any suggestions?
  • Bosch Master
  • 2,963 Answers
Owner's manual no manual? Try MFG website or email their customer service, or try
manualslib.com
What does container mean? Water condensate bucket? or similar?
Posted on Apr 12, 2015
dutchman05
  • 487 Answers
SOURCE: Bosch Classix 1200 washing machine
check the water in let valve connections and the current over it when it is in the fab cond. cycle. Replace valve if current is on. Valve price range is 15-35$
Posted on Apr 17, 2008
barkencoa
  • 3463 Answers
SOURCE: drum not working on bosch washing machine
I would say that the brushes want replacing in the motor, access to the motor is by removing the rear panel, remove the belt, and undo screws securing motor, remove motor, brushes are located at rear end of motor.
Please rate my solution.
Thanks
Posted on Nov 08, 2009
aardvarkrepr
  • 62 Answers
SOURCE: Bosch classix washer dryer has just flooded water
Several possibilities.
  1. Was water poring out of the drawer when the appliance was in spin?if so then possible cause is that the appliance hasnt draqined its water first. It is trying to spin with water in drum and it has to go somewhere.
  2. Is the appliance overfilling? Water level should just come to the bottom of the door but if you see it rising up to the top of the door then you have a problem with the water level sensor (or a blockage)
From experience with the type of fault you have i would say that its not draining all the water before spin. If you have a pump out function then do this a few times until ALL the water has drained. put a large towel in front of bthe filter and unscrew filter cover and check for a blockage.
If you cant find anything then you may need to call a engineer
Hope this helps
Aardvark Repairs
Posted on Nov 16, 2009
Testimonial: "Helpful advice given in a structured way. Many thanks"
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
  • 662 Answers
SOURCE: my bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Jun 16, 2010
Ecologixx 7. Why does it keep switching itself off?
could be the door switch has failed . try leaning on door when starting .
Sep 13, 2015 | Bosch Washing Machines
Bosch WTL5200SN/04 condense Tumble Dryer
you have to open the cover to check it seem the water tube is dissconnected or there is an blockage in the tube.
Jul 07, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My bosch classix 6 condenser dryer is now taking too long to dry the clothes.I regularly clean filters and empty water container after each use.Please help.
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Jan 11, 2015 | Bosch Dryers
My Bosch classix dryer is not drying the clothes. The drum is turning & it feels very hot on the inside & on the outside of the machine. There is a lot of condensation around the edges & where...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 11, 2011 | Audiovox Bosch 718 World Cellular Phone
Bosch classix washer dryer has just flooded water through its door and drawer whilst on a cycle. Any suggestions?
Hope this helps
Aardvark Repairs
Nov 16, 2009 | Bosch Classixx WVF 2402 Front Load...
Drum not working on bosch washing machine
Thanks
Nov 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch dryer warning sounder for container full will not stop
Hi
You need to remove the left side panel, this is the side where the drain container is, once removed you will see the drain pump with two pipes coming from it, remove the pipes and top cover, disconnect the wiring, remove the pump unit with the clip, clean the float unit and pump, also remove the congealed mess in the water trouth as this is what holds the float up and makes the machine think the drain container is full.
I bet you will find this will cure the problems you are having, it did with mine.
Sep 07, 2009 | Bosch Dryers
I have a bosch dishwasher that wont drain
Question! Did u buy this from Bosch? If you did not, then your contract is with the Store you bought it from and NOT Bosch and you should be contacting them and they should sort the problem.
A blockage, can sometimes be solved by putting one of those diswasher cleaning tabs in the machine a couple of times and see if that sorts the problem for you.
I suggest do that first it is the cheapest option and then if that does not work ring who you bought it from whether that be a retailer or Bosch themselves.
Jun 18, 2009 | Bosch 24 in. SRS43C12 Classixx Slim-Line...
My bosch classix washing machine is not dispensing the fabric conditioner properly. Often the fabric conditioner is left in the dispenser unused, just now it went in with the washing powder. It has...
The water going in to the dispenser is blocked by sludge.
Remove the dipenser tray.
Look up inside the tray hole, at the 'roof' of the tray hole, and there are four holes (square on my machine) where the water flows in - in the middle of the 'roof'. These will be blocked with sludge. Try to poke them clear with a nylon tie or plastic coated wire - should go in a few inches.
It worked for me.
Aug 06, 2008 | Washing Machines
Condenser tumble dryer water problem
Took advice...isolated from electricity supply...removed left side panel (side with condenser tank), to access the pump. Cleaned it all out (masses of water and grey lint!) and put it all back together again. Bit fiddly getting the panel back on...no screws left over...result!
All working great now.
Simpler solution maybe...There is a 'trap door' that can be removed, which gives access to the area where the water and lint accumulate.
1) Isolate from electricity supply.
2) Take out the condenser unit at the bottom LHS front of the machine (routine maintenance).
3) Underneath of where the condenser unit usually lives..at the back...reach in and open the 'trap door'. This needs a flat head screwdriver and you must release the two plastic clips holding the trap door.
4) You can now access the area where the water and lint accumulate...which makes the 'float' give a false container full fault.
5) Clean out this water and gunk regularly (once a month)!
Hoping this will avoid taking the side panel off again...
Jun 02, 2008 | Bosch WTE86300 Electric Dryer
Washing Machines Logo
56 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
