Question about Apple iPod classic MP3 Player
Can't reset. When I run a sdram full test It says RUN: BL on, PASS: BL blink, FAIL: BL off, reset to continue. What does this mean?
My Ipod got dropped. I have been attempting to reset it, but Itunes says there are files being used by another app, so it's stuck.
  • Apple Master
  • 389 Answers
Have you been trying to reset it from backup? If so, you need to set it up as a new device. You may have to use someone else's computer if that still doesn't work. Also, just to make sure you have the right steps...
Can't reset. When I run a sdram full test It says  - 25642545-by3y5nundqgrma0wsf20kqmz-1-0.jpg
Posted on Oct 04, 2015
2 Suggested Answers
SOURCE: Older ipod classic blinking : SDRAM
switching the power buttong from off to hold a few times and then simultaneously pressing Menu and Select buttons worked! omg thank you so much! =D
Posted on Feb 19, 2011
Ipod HD or logic board gone? SDRAM full test freezes!!!!
Getting the components wet is not a good start. There is most likely liquid damage on the parts even if you can't see them. And even over time corrosion to iPod can happen. Much like the Statue of Libery, it used to be copper, and now its green from long exposure to moisture.
Mar 09, 2017 | Apple iPod video 5th Generation
Older ipod classic blinking : SDRAM FullTest Please wait...... Run: BL on Pass:BL blink Fail: BL off Reset to continue. Cannot do anything to stop it or reset it????
Nov 20, 2010 | Apple iPod MA446LL/A MP3 Player
What is the drive cycle for a 1998 Aurora, Battery was disconnected and need to reset sensors. Will not pass or fail smog test. Was told that i needed to do a Drive Cycle to reset the sensors?
This means you must drive the car long enough for all of the self-tests to run. Depending on the test it could be a single start and run to many cycles and many miles. Usually after about 50 miles of driving you have completed most tests.
I'm not sure where you are located, but in Ohio you can ask and have the car run on the dynamometer and compete your smog test this way.
Oct 11, 2010 | 1998 Oldsmobile Aurora
My liftmaster will not operate and my led light blinks 5 times. What does that mean? Thanks
That code is RPM sensor or motor overload. When the RPM sensor goes bad the motor will still run for a short time. If the motor has been run several cycles it will turn off on the thermal overload and won't reset for about 15 minutes. The resetting is automatic. Is your door stuck in the open position?
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Stuck on sdram full test, how to reset?
visit the link below: It will guide you on how to reset your ipod.
Read and follow steps/instructions gradually on how to reset your ipod.
http://www.wikihow.com/Reset-an-iPod
Good luck.
Apr 22, 2010 | Apple iPod MA446LL/A MP3 Player
It says sdram full test reset to continue and is flashing
make sure your ipod is in the on position push the middle button & the menu button @ the same time for about 5-10 seconds you will see and apple appear just let it reset itself
Jan 08, 2010 | Apple iPod MA446LL/A MP3 Player
My ipod ask for a reset so now it stuck on the screen that says sdram full test reset to continue
press the MENU and CENTER buttons together for about 10 seconds, while connected with the USB cable to your PC.
Aug 29, 2009 | Apple iPhone 3G
Ipod 30GB
There may be 2 solutions for this problem:
The 1st solution:
The first thing you should do is locate the lock button on your ipod. Second make sure it's unlocked, lock it and wait for one second and then unlock it. Finally hold the inner Grey circle button in the center of the ipod until you see the apple logo appear on your screen.
The 2nd Solution:
Plug in your ipod and click on your ipod in your itunes library. By doing so you should be on your contents tab. Click on the settings tab and then click on restore. This should restore all your defaults on your ipod. Before you do all this; make sure you back up1.gif your ipod library if you don't currently have them in your itunes library.
If this solution helps you out please give rate me and leave a comment. Thank you...
Mar 15, 2008 | Audio Players & Recorders
Apple iPod classic MP3 Player Logo
103 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
