Question about Motorola Mobility Elite Flip HZ720 Bluetooth Headset - Silver Original OEM 8950
Why does my Elite Flip keep switching back and forth between paired and unpaired?
Keeps flashing. Says its paired then its not and keeps repeating to go back to Bluetooth menu to connect
  • Official Brand Answer
  • 1,623 Answers
Hi Corinna...
You can try a reset. Here are the instructions:
ELITE FLIP Reset to factory default
Best Regards,
Katy
Motorola Support
Posted on Apr 29, 2015
  • 3,100 Answers
Corinna-
Let us know if you require additional assistance.
Motorola Support
Posted on May 04, 2015
2 Suggested Answers
  • 6702 Answers
SOURCE: My Motorola Elite Flip Bluetooth will not pair with my new Samsung s5. Can you help me
page 19 and 20 of the manual tell you what to do if the flip won't pair. https://motorola-global-portal.custhelp.com/ci/fattach/get/634666/1370266396/redirect/1/filename/Elite_Flip_GSG_68017335001A.pdf
Posted on Jan 13, 2015
What causes an echo problem with Motorla elite flip paired with a Samsung
You should not have an echo. Can you try pairing with another phone to see if you have the same experience?
You may try resetting the headset ( ELITE FLIP Reset to factory default )
Mark
Motorola Support
May 31, 2014 | Motorola Mobility Elite Flip Bluetooth...
How can I enable the Bluetooth in my handa forza 2007 motorcycle?
follow this instruction. God bless you
To turn on Bluetooth discoverability, first key on the motorcycle. Leave the kickstand down and the kill switch off to keep the motorcycle disarmed. Toggle the Mode switch back and forth between Eco and Sport modes at least 12 times. Once the motorcycle is discoverable, the green "Armed" light will flash for a few seconds (except on FX and XU models. With the FX and XU models, the red warning light will blink slightly faster). It may take up to 10 seconds for the motorcycle to become visible to your Bluetooth device.
Once discoverability is enabled, the motorcycle will remain discoverable until paired with a phone, or until the motorcycle is switched off. Once you have paired your phone with the motorcycle, you will not need to repeat the discoverability process to connect to it.
Jul 20, 2013 | Computers & Internet
How to know which wire is for what on a 3 way circuit?
This is easy enough by process of elimination. With power off, connect any two of the three wires together. (A) Turn power on. Flip the other switch back and forth. If the light does not go on, then the wires you connected together are your travelers and you are done. If the light goes on in either position, then the wire you DID NOT connect together is one of the travelers. Turn off the power and mark your known traveler. (B) Now disconnect the original pair and connect either one of the original pair to your known traveler. Repeat from (A) to (B)
Aug 08, 2012 | Electrical Supplies
I just bought the Elite Flip earpiece. It is pairded. While driving I receive a call I have to retrieve my 3G I phone, turn it on, accept the call, then press the elite flip bar in order to use it...what...
It *should* connect to your phone by just pressing the call button with a call comes in. (They all work this way). My guess is, based on your description, is that you are not just pressing the call button, but holding it. This resets the headset back to default and unpairs the phone. When you receive a call (after making certain it's paired) is to just tap the call button once.
Apr 27, 2017 | Motorola Mobility Elite Flip Bluetooth...
Motorola hs850 bluetooth headset won't pair with Blackberry Curve
try to delete it out of ur phone all the way and then try to pair it again
Dec 15, 2008 | Motorola Mobility HS850 Consumer Headset
Please help with Samsung WEP410 Headset Problem
As Quoted from Arfur - see bold print if you are having problems. You don't need to unpair the other phone, it will unpair itself.:
>Paraphrasing from the manual:
>1. Turn off headset.
>2. Press & hold the Multi-function button for 8 seconds, until >the lower half is lit up blue (not flashing).***THIS IS >IMPORTANT! KEEP HOLDING IT IN UNTIL IT STOPS >FLASHING! The whole thing will be lit up blue, but the lower >half will be brighter.
>3. Set your 'phone to discover bluetooth devices.
>4. Your 'phone will find the "Samsung WEP410" headset, & >ask if you want to pair with it. Confirm by pressing "Yes" or >"OK".
>5. Enter passkey or PIN "0000" (4 zeros), then "Yes" or "OK".
Aug 05, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Pairing problem
Jun 06, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Samsung wep410
Jan 15, 2008 | Samsung WEP410 Bluetooth Headset Wireless...
Motorola Bluetooth HS850 Pairing Mode
was soooo helpful just make sure u do flip it open immediately after, thats were i messed up... Thk
Sep 16, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility Elite Flip HZ720 Bluetooth Headset - Silver Original OEM 8950 Logo
211 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
