How do I open the case of my Roberts sports DAB 2 Radio?
How can I open a Roberts Sports DAB 2 radio? Serial number is 10609273. The on-off switch has been intermittent for some time and has now failed completely. This may be due to dirt getting inside the radio so I want to open it and try to clean it. I have tried to open the case using my Fixya spudgers but it is firmly fixed at each corner and there are no screw heads or other fixings visible.
SOURCE: how do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Posted on Nov 10, 2007
  • 30 Answers
SOURCE: error code er 2
I dont want to guess a solution for this however, ERR2 represents EJECT. The description of this error is "The Eject is not available". Possibilities are, jammed mechanism or sticky eject button.
Posted on Sep 06, 2008
SOURCE: Kensington Expert Mouse [USB on a Mac]
I bit the bullet and peeled up the two bottom corners of that sticker and sure enough, there were two short Phillips screws there holding the assembly together. With those removed, it came apart nicely (be careful and don't lose the little idler roller when you dissect the assembly) and the rollers and their shafts can be thoroughly cleaned using tweezers and alcohol. Works perfectly again.
Posted on Nov 08, 2008
SOURCE: How to work / setBuch radio alarmclock
I just found my manual for the Sharper Image SI785 CD/Radio Alarm Clock with Sound Soother. Had misplaced it for quite a while. Am not saavy enough to know how to post it online, but if anyone needs one, just email back your address and I'll be happy to send it. I remember how frustrating it has been trying to program/reprogram one without it. Looking forward now to knowing how to use this thing :)
Posted on Nov 18, 2008
  • 24 Answers
SOURCE: I want the cd key serial number of EA sports cricket 2007
Try this __Inform me if it works.
Posted on Apr 02, 2009
My radio isn't working we changed the battery just this morning and now the Radio doesn't turn on at all.
radios have an anti theft device in the system that cuts in when the battery or the radio is removed or disconnected
If the radio is factory fit and not very old you should be able to get the code from the dealer
if not there are free download sites that have radio codes for all makes and models
all you have to do is search your make of radio, model of car and if you have it the serial number of the radio
Jul 01, 2015 | 2003 Ford Escape
Where can I get a replacement off-on switch for my ROBERTS ECOLOGIC 4 DAB/FM PORTABLE RADIO? The mains light is on, but the radio doesn't work and I see that this is a noted fault of this model. Is it
If you cannot get parts from the manufacturer you may end up directly connection the wires to have the radio on continuously or installing an aftermarket switch.
Feb 04, 2015 | Roberts Audio Players & Recorders
How do I open the case on a Roberts SprtsDAB2 radio to change the aerial?
check that the antenna is not a push in or screw in application
Jan 03, 2015 | Cars & Trucks
Ford dab radio keycode for serial number v010799
http://www.radio-code.lt/login
I use this site and it is great. You will have to register (which is free!) and you will need the make of the radio, model, serial number and then it will issue you the radio code immediately.
Apr 26, 2014 | Cars & Trucks
Can you give me the radio code for blaupunkt
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Jul 03, 2011 | Blaupunkt Nashville DAB35 CD Player
Hi i have a renault megane 225 sport 2004 and i need the code for the radio , i am a lady owner so have been unable to get the radio out for the serial no
The radio has to be removed from the dashboard
Then post the 14 character SERIAL NUMBER beginning with RN* * * * * * * * * * * * found stamped in the metal casing.
Also post the SECURITY NUMBER. This is found on a label on the metal casing in the format TOA123 or TA123 or just A123 at the end of a barcode
If in doubt post ALL the letters+numbers on any labels or barcodes
Oct 20, 2010 | 1986 Renault Sport
Need a radio code for 2001 mitsubishi montero
need radio code for 2001 Mitsubishi Montero sport. Serial number J44mT21H91P001563. I replaced the battery which reset the radio. My email: Adana_great@yahoo.com
Feb 13, 2010 | 2001 Mitsubishi Montero Sport 4WD
Radio code
you'll have to have your vin # as well as the radio serial and part # handy call 1888mitsu2008 and they will help you with your code free of charge
Jun 16, 2009 | 1999 Mitsubishi Montero
Need manual for Alba Clock Radio CRDAB301
Sorry m_gerard, I can't help you with the manual.
However here is a partial list of operations for the Abla CRDAB301:
Switch on
  • Press STANDBY
Switch off
  • Press STANDBY
Factory Reset:
  • Switch the radio on;
  • Press and hold MENU for 2 seconds
  • Press SELECT.
Switch between FM and DAB:
  • (radio must be on)
  • Press DAB/FM
Tune & store all DAB stations:
  • Press MENU
  • Press ">" three times (or until display says "Autoscan full")
  • Press SELECT
To listen to another DAB station:
  • Press "<" or ">" until the station name is displayed
  • Press SELECT
Hope that helps!
Apr 20, 2009 | Audio Players & Recorders
Radio code
I have a 2001 Mitsubishi Sport. I was doing some work to my battery and my radio locked out. I put a code in that I thought it would be and after 3 codes it would not let me add anymore codes. I took my vehicle to the dealership(no charge) and he went in and got the serial numbers off of the radio and looked into his computer and gave me the code. Of course the radio was locked out. He told me I had to have the ignition turned on for 30-45 minutes and the radio would reset for me to put the code in. I let it sit in the garage for an hour and went back out and it worked. I just put the code it.
Feb 14, 2009 | 2001 Mitsubishi Montero Sport 4WD
70 people viewed this question
 Grubhead
Grubhead
