Question about LCN 4041 Hw/PA Hold Open w/62PA Arm Door Closer
It holds door open but wont close all the way because hold open is engaging on both ends
Drivers door will not latch closed
It appears that the door is not closing far enough for the latch to move to the second position in it's movement. ie on not closing the door properly you will see that it is latched but not closed . Push it harder and it closes properly. Lubricate the latch mechanism and you may have to adjust the catch position to allow the lock to go to the fully locked position POssible rubbers to cold and stiff to allow the door to close easily
Feb 03, 2013 | 1997 Ford Escort
The auto clean was pushed while the door was half open, the lock engaged and will not reset.
If you can open the door since it wasnt fully closed when the lock engaged..open the door,push in and hold the oven light switch, and push the cancel button and the lacth should open
Aug 28, 2011 | Kenmore 95410 Kitchen Range
Can not open the door in microwave the release button springs seem to not working can that be fixed. Have opened the release button but cannot see the problem
Do not pry the door open since there is an easier remedy which will lead you in the direction that you need to fix your problem. Take the cover off after you disconnect the power to it. Once you have taken the cover off (only a few screws) you will be able to see the two latches that hold the door closed and the link that opens both of them. You can just lift both latches at the same time and it will open. After you have done that take a good look and press in on the open door button and you will see where you have the problem of the door hanging. That button should push a linkage that pushes up on both latches at once to open the door. It is spring loaded so that it comes back down so that when you close the door it will hold the door close.You need to take the cover off the microwave so that you can pull both of the latches that hold the door closed up. When you push the button in it engages a linkage that pushes both taches up at the same time to open the door. It is springloaded and will come back down during normal operation to hold the door closed when you close it again. That area is where your problem is. By looking at what happens when you press the open door button you should be able to readily see where the problem lies in that linkage
Feb 12, 2011 | Sharp R-1610 Microwave Oven
Doors freeze up wont shut close after opening interior light then stays on
Look at the end of the door where the latch is located. The latch may have flipped to the closed possition when the door was open.There is a U shaped piece that when the door hits the post on the door jam it flips up to hold the door shut.If you can get the passinger door open you can see what it looks like in the open position. If this is the problem just hold the door handle like you are opening the door and with a srew driver or even your finger you can push than U piece back down.To keep your door from freezing shut try putting sone silicone spray on a paper towl and wiping it on the rubber door seal.Spray a little on the door latch as well.
Dec 28, 2009 | 2001 Ford Taurus
Self-cleaning door lock is engaged and door won't close. How do I get door look to release so I can close the door?
I would first try resetting the breaker or unplugging the unit for a minute or two and see if that yield`s any success. If not...
Try holding the door switch pushed in.(or held closed in electrical terms) This may require a second person if you can`t reach the clock/timer while engaging the switch. With the switch held, set the unit for self-clean, let the lock advance to a "locked" position and once it indicates it is locked press cancel while still holding the switch closed. This should in theory force the lock to advance to it`s open/unlock position.
Hope that help`s. If so please rate the solution I provided.
Thanks for visiting fixya and good luck.
macmarkus :)
Dec 08, 2009 | Frigidaire Ovens
Door wont stay shut
The door latch could be closed, in other words, the door thinks it shut into the striker. Take and hold the door handle open, like your trying to open the door, hold the handle out or up and at the same time open the latch, it may be stuck or closed...If that's not it, you may have to re-align the latch to the striker, the striker will come loose with a torx bit. Loosen it up, and move it around and re tighten, it's a trial and error deal, just keep trying different positions until if works right...
Feb 25, 2009 | 1998 Chevrolet K1500
Oven door will not close because the door lock is on and flashing, also the oven light won't go off. how do I fix the door lock flashing so I can close the oven door completly?
is not actuallly physically closing??? perhaps the lock/ latch has partially engaged prevetning door from closing, and with the door oopen it cannot do anything for safety reasons. can you see a door /light switch thtyou can depress by hand??? if so push and hold it in the light should go out, and at this point continue to hold in switch and try starting a self clean cycle ( dont worry it wont actually start cleaning right away)it then should activet the latch assy to fully engage and suppoedly lock door, still depressing the button then press thecancel button and the latch should return to the normal resting position and you can close the door
Apr 03, 2008 | Ovens
My oven door will not close it has a lock button showing can't cancel
make and model??
Apr 01, 2008 | Kitchen Ranges
Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Dec 28, 2007 | Electrolux EOC6690X Pyrolytic Electric...
LCN 4041 Hw/PA Hold Open w/62PA Arm Door Closer Logo
385 people viewed this question
Top LCN Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a LCN Hardware and Accessory Expert? Answer questions, earn points and help others
