Question about Sony ICD-SX25 Handheld Digital Transcriber / Recorder
Digital voice editor
It repeatedly crashes when recorder is connected to computer
4 Suggested Answers
  • 207 Answers
SOURCE: No voice recognition
You must have already set up and trained a user with the Dragon NaturallySpeaking software prior to transcription. Make sure that the Digital Voice Editor (DVE) software is not opened prior to starting these steps.
Open the Dragon NaturallySpeaking software.
The Dragon Bar window opens. From the Dragon Bar menu, click the Sound button.
From the Sound button, select the Transcribe Recording menu item.
The Transcribe a Recording dialog box opens.
Click the large square button to the left to start the DVE software.
The Digital Voice Editor window opens.
NOTE: If the file you want to transcribe is still on the Integrated Chip (IC) recorder (which will be reflected on the left side in the IC Recorder window), you will need to connect the IC recorder to the computer using the supplied USB cable, or transfer the file to the computer.
Select the item you want to transcribe from the PC window on the right side.
Click on File from the tool bar.
Select the Voice Recognition menu item.
The Converting.. Dialog box opens.
The Transcription Options dialog box opens.
Click the Transcribe button to continue.
The Transcribing window and Dragon Pad window opens.
The text is displayed while the transcription is in process.
NOTE: Once the transcription is complete, it may be necessary to make grammar, word, punctuation, and formatting adjustments.
To save the text file, click on File from the tool bar.
Select the Save As. Menu item.
The Save As dialog box opens.
Browse to the folder location to which you want to save the text file and double-click on that folder.
The folder you chose should now be showing in the Save in drop-down box near the top.
Type in the desired File name in the File name drop-down box towards the bottom and then select the document type.
Click the Save button.
Click the X (close) button in the upper-right corner to close the Dragon Pad window.
Click the X (close) button in the upper-right corner to close the Digital Voice Editor software.
Posted on Feb 12, 2010
  • 2841 Answers
SOURCE: I would like to get
Sorry, but the Sony IVD-MX20 is not Mac OSx compatible and there is no software to make it compatible. However Olympus does make voice recorders that are compatible with Mac.
Posted on Dec 21, 2010
  • 109 Answers
SOURCE: My operating system is Windows
it will be available from the sony website. most of the 32 bit versions also work with 64 bit
Posted on Apr 05, 2011
  • 3530 Answers
SOURCE: I'm using a Sony ICD-BM1
Welcome to Fixya
As part of the test. Try to copy files (pictures) to the device and see if the device were able to save the file. If not then try to format the device. Please take note that formatting the device will delete everything. see procedure below:
1. press menu 2. using the jog lever, select format 3. press enter 4. use jog lever and select yes 5. press enter -> Ok? -> press enter 6. formatting will be displayed on the screen. press menu after formatting the device and test the issue.
Thank you for using Fixya!
Posted on Jun 08, 2011
0 characters
1 Points
How do I put the recording into my mac on an mp3 file?
The supplied Software with the IC Recorder is not compatible with the Macintosh Computer. Hence, it is not possible to transfer the recordings to the Computer using the USB Cable. However, you can connect the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Recording Software to capture the files.
Feb 05, 2010 | Sony ICDP620 Digital Voice Recorder
Problems to make the sony icd-sx25 software editor recognize my hardware when i connect to pc with usb cable. using a windows vista home premium 64 bit operating system
There is Sony Digital Voice Editor Version 3.2.01 available to work on Windows Vista Home Premium 64-bit.
Click Sony Support to download "DVESetup_EN_3201" file (size approx 83MB) and install it in your computer, this will solve your problem of ICD-SX25
Jan 29, 2010 | Sony ICD-SX25 Handheld Digital Transcriber...
Rewinding to listen to recording
You should use the computer with Digital Voice Editor software to have more options when trabscribing. You could then use the transcribing keys to playback your recordings and regulate the velocity of the playback.
Download Digital Voice Editor Version 3.1.03 for Windows Vista/XP/2000.
64 bit version operating systems are not supported, though
Jun 08, 2009 | Sony ICDP620 Digital Voice Recorder
Using ICD-P210 and BP-150, use same software?
I borrowed Sony Voice Editor 3 (version 3.0) from a colleague and can now download and play both the P-210 and BP-150 with one program.
Apr 23, 2008 | Sony ICD-P210 Digital Voice Recorder
Sony ICD-SX25 Handheld Digital Transcriber / Recorder Logo
29 people viewed this question
Top Sony Voice Recorders Experts
Mike McWhinney
Are you a Sony Voice Recorder Expert? Answer questions, earn points and help others
