Question about Electric Health & Beauty
My Mach 1 electric scooter charged one day used one day now won't charge
It says when charging the red and yellow light by won't go to green. It's been on charge for8 hours and won't even ride 2 mins is it the battery? Should I take the keys out whilst charging even tho there off I don't no what else to do only had the scooter 3 days the seller won't return msg
  • Electric Master
  • 2,195 Answers
I would take the batteries to a place that sells auto batteries and have them checked Sounds like they may be no good. Take to an independent store as there is no charge to check them Have them write down what they found and then go back where you bought it.
Posted on Apr 12, 2015
  • 39 Answers
SOURCE: Have Zoom 220 HMV 3 wheel scooter. Charged battery
It is possible the the battery could be damaged after being stored for that length of time. If it was wasn't completely charged before storage, or if it was exposed to extreme temperatures (even for a short amount of time) you may need to find a replacement battery. http://www.batteryinternational.com/electric-scooter-batteries.html should have the battery you need.
Posted on Jun 23, 2009
  • 11 Answers
SOURCE: Battery will not charge
Those batteries are probably dead, you have to charge them every so often if you are not using your scooter or chair. You also have to move it so the tires don't wear down and go flat.
Posted on May 18, 2010
FixinFax
  • 3085 Answers
SOURCE: Electric 3 wheeled mobility scooter wont move
Look at the rear of the scooter, make sure the Free Wheel lever is engaged
Posted on Jun 27, 2010
  • 346 Answers
SOURCE: charged up after xmas .turned
PLEASE DOWNLOAD AS A PDF FILE:SHOPRIDER SERVICE MANUAL 2007 1-800-743-0772 IM DISABLED MYSELF & UR MY REASON FOR BEING HERE.IT GIVES ME MY STRENGTH,COLIN.
Posted on Mar 14, 2011
SOURCE: I charged up the battery
My AUTOAGO power chair was loaned to a friend that ran a daycare. She parked it for month between foot surgeries. One of her children likely moved the transmission lever to neutral. So even with fresh batteries all the lights on the battery indicator were flashing. I took to a shop and they showed me the lever. All is well now.
Posted on Jul 30, 2011
I got a brand new electric scooter a Mach 1 1600 w but when I pluged the charger in it goes straight on the green light is that normal it ain't been fully charged yet
Hello,please ask who the scooter was purchased from.If you start taking things apart or the like,they could say.You should have came back to us and it could affect your guarantee.I believe going back to the last person you deal with can save a lot of problems,I hope this helped.Colin
Jan 05, 2015 | Electric Health & Beauty
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
My charger light shows always green and it does not charge the scooter.
Usually that means the battery is not able to hold a charge.
Jul 29, 2012 | Razor E100 Electric Scooter
HI Scooter is on charge full time and used daily after 30min i loose the first green light that is OK but if i dont use it for one or two days i loose the first green light only after 10min can you...
well it could be that you overcharged the batteries. You should not leave the scooter on the charger full time. you should charge the scooter nightly while you sleep unplug from the charger when you get up in the morning. the charger should not be on the scooter more than 12 hours per day and that rare. Whenever you have a red and green light on the charger the scooter is fully charged and can be unplugged. Always put it up fully charged and then charge after each use. Your batteries need to be replaced and charge the new ones before use then charge overnight each day that you use the scooter. If you don't use it for a few days you should still be fully charged than charge after use Hope this helps
May 12, 2011 | Invacare Supply Group Invacare Scooter...
Low hour, RASCAL 600 has been in clean safe storage with new batteries won't charge, no amp meter reading, no fuel gauge reading, yet charger itself has red and green light showing. If and when the...
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
May 08, 2011 | Health & Beauty
Invacare m51 scooter. I just replaced the batteries in my dads chair. We charged it all night the first night and it ran great the next day. recharged it for several days after using it and now the battery...
Sweet you do not need to leave the charger plugged in for several days. Sounds like there is a charger problem When you first plug the charger in with batteries depleted you should be getting a red and yellow light with the yellow turning green when fully charged. now the charger (built in) could have become unplugged from the power module located in the rear of the chair behind the black cover. To get to it you have to remove the seat, shroud and batteries then using a phillips screwdriver and adjustable wrench remove the black cover. The charger cord will be the last one on the left with a small 4 pin white plastic plug make sure it is well seated in the power module. If it isn't loose then you have a problem with the charger or the circuit. Now if you know of a friend that has an off board charger for a chair or scooter that you can borrow you can charge the batteries using the charger port located under the front of the joystick Plug the charger into the port then into the wall socket and let er rip Charge until the light turns green overnite is a good habit to get into If the onboard charger is bad I would suggest you by an offboard charger (cheaper) Now if Medicare paid for your Dads Chair then they will pay for any repairs even batteries and you can contact the provider that your dad got the chair from to see if they will repair it Hope this helps
Feb 17, 2011 | Health & Beauty
How to charge my panterra transport scooter,do i leave switch on or off and for how long?
tony you can charge it either way with switch on or off and if you have used the scooter alot during the day and the battery level lights are in the red charge overnight. The charger light will turn from yellow to green when the batteries are fully charged It really is a good idea to get into the habit of charging overnight wehn you have used the scooter all day. It helps the batteries to recycle them thru a charge cycle when they run down. Now if the scooter is used rarely then make sure it is fully charged when it stored and charge once a week when idle. Hope this helps you
Sep 09, 2010 | Health & Beauty
Health & Beauty Logo
166 people viewed this question
Top Electric Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
