Question about Campbell Hausfeld Air Tools & Compressors
Need wiring diagram for campbell hausfeld 3/4 he tankless air compressor
  • 8 Answers
SOURCE: Campbell Hausfeld Air Compressor auto shut off switch not working
i have the same one and mine was broken by my kids , i had to replace the entire component, DONT RUN COMPRESSOR with out the regulator working IT CAN EXPLODE IF OVERFILLED,a must fix situation i believe i got mine from sears , a great unit ive used it painting and with many air tools over many years now , well worth fixing mine is a little loud but dependable good luck.
Posted on Mar 15, 2009
  • 89 Answers
SOURCE: help! air compressor trouble.
ASSUMING YOU ARE TALKING ABOUT THE PRESSURE SWITCH. YOU SHOULD EITHER HAVE 2 WIRES OR 4 WIRES ON THE SWITCH. THE SWITCH IS TYPICALLY MARKED LINE-LINE-LOAD-LOAD. IF YOU CAN SEE THE INSIDE OF THE SWITCH YOU WILL SEE THE CONTACT POINTS. ONE CORD WIRE CONNECTS AND PASSES THRU ONE SET OF POINTS TO ONE WIRE OF THE MOTOR. THE OTHER CORD WIRE PASSES THRU THE OTHER SET OF POINTS AND CONNECTS TO OTHER MOTOR WIRE. YOU TYPICALLY WILL NOT HURT THE COMPRESSOR BY HAVING THIS WIRING INCORRECT - PROBABLY JUST POP THE BREAKER INSTANTLY. IF YOU CANT SEE THE PATH THRU THE POINTS YOU CAN OHM THRU THE POINTS AND GET A CONTINUITY BEEP ON A VOLTMETER. IF THATS NOT AN OPTION, JUST SWITCH THEM AROUND UNTIL IT RUNS. HOPE YOU BOUGHT THE SAME CUT-IN AND CUT-OUT PSI. GOOD LUCK AND WRITE BACK IF THIS DOESNT GET IT. JODY
Posted on Apr 07, 2009
  • 234 Answers
SOURCE: air compressor not working
If your motor is running and not the pump, the malfunction is either in the pump or the coupling between the motor and the pump.
Some of these compressors are manufactured so cheap now that there can be just a set screw that is loose and the motor shaft is spinning free inside of the crankshaft.
If you drain the oil out of the pump and take off the pump crankcase cover, you should be able to see the problem.
Posted on Apr 15, 2009
  • 98 Answers
SOURCE: I have a Campbell Hausfeld Quick Air DK618300AV without a fuse...
3.5 amp fuse
Posted on Jul 22, 2009
SOURCE: Campbell Hausfeld Air Compressor won't start
The compressor starting problem is common to most of the small portable compressors. Poor design and undersized components are to blame. If you have one of these units i suggest looking into a product called the Smart Start by Conrader Valves. It is interchangeable with the standard air filters and allows the compressor to start without fail. check it out- www.conrader.com.
Posted on Jul 23, 2009
Campbell Hausfeld Air Compressors motor shoots fire
You may have a short in the motor itself. You may need to have the electric motor checked. It could be dangerous to continue using .
Apr 23, 2012 | Campbell Hausfeld 3/8 in. NPT Compressor...
I would like a wiring diagram for model #FP200300AV serial #00174170
You can try finding it here but you may need to send an email to the company and request the wiring diagram. I could not find one online for you.
http://www.chpower.com/webapp/wcs/stores/servlet/XManuals?storeId=10051&catalogId=10001&langId=-1
Jul 13, 2011 | Campbell Hausfeld 2 Gallon Air Compressor
Campbell hausfeld mod wl611700aj runs for 3-5sec
If the motor isn`t bad,then the one way (check valve )is not working,putting to much pressure on the head.
Oct 05, 2009 | Campbell Hausfeld 28 - Gallon Air...
Need a wirring diaphram
At the risk of sounding stupid, did you try their website?
May 24, 2009 | Campbell Hausfeld 28 - Gallon Air...
Air compressor head gasket diagram
Campbell hausfeld has all their manuals on line at www.chpower.com / you can enter the model # of the whole unit or just the # of the pump. Also you can enter just a partial number example wl650 for a list of models is that range. Use caution when installing gaskets for chpower oiless pumps. Some of their gaskets are very brittle. After installing parts, turn pump by hand to make sure all parts are in their proper place and that there is suction. Enjoy
Dec 02, 2008 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
71 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
