Question about Speed Washing Machines
Why is my speed dial running counterclockwise?
It started doing this intermittently. Now when you flip the switch it just spins in counterclockwise (slower speed)from operator side. Whole speed pot in back is spinning too.
    Genius:
  • Speed Master
  • 1,585 Answers
Whould put me in mind somthings got rev pollirty
Posted on Apr 27, 2015
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
Hobart A200 mixer won't start
My fantastic guy just rebuilt my A200. He says it's likely that your back plate is slightly off center so that the center arbor is touching the windings-- any contact and the machine won't run. The tolerances are thousandths of an inch in there.
Nov 21, 2011 | Hobart A200 Stand Mixer
My timer manual switch works,it turns the outside lights on and off. However the automatic dial,even when plled out and set to time to operate does not work.What 's going on? Isit me?
The two tabs are for On ad OFF.
One is slightly longer than the other. If the OFF tab is in the ON location, it won't work, it'll just click past the time and not flip the paddle to ON.
Try this, turn the dial (NOT pulled out) around slowly and see if it flips the paddle to ON. Keep turning it, slowly, and see if it flips to OFF.
If it works while you're "helping it" then it should work automatically. If it doesn't, maybe the gear is damaged and it can't move past a certain point.
Does the time move? Do you hear the motor running? I've seen the motors go bad. The manual flipping will work then, but the motor isn't running the clock around.
Jan 30, 2011 | Intermatic T101 - 24 Hr. Dial Time Switch...
Kenmore Series 90 intermittent spin. Washer will go through normal wash cycle, but will often not spin during rinse or spin cycles. Upon observation, machine was seen to appear to "lock up"...
I used-to-be a big fan of Craftsman & Kenmore
but after intensive abuse I got better)...
Great trouble description...
(& trouble shooting))
Sears
has a fairly decent on-line "CHAT"
(and have been trending toward competitive)
To encourage PARTS PURCHASES...
Once they conform my "CONTROL BOARD"
hypothesis...
Check prices at :
appliancepartspros
Search Over 2 1 Million Appliance Parts
repairclinic or
Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
partssellect... all have do-it-yourself VIDEOS.
PartSelect Appliance Parts and Repair Help
And last (in my opinion certainly least)... SEARS
Water Filters Lawn Garden Appliance Parts
Mar 06, 2017 | Kenmore Washing Machines
Spin cycle starts, speeds up, then stops spinning
This fault often occurs when something (like a small coin or a paper tissue) has blocked the drain pump!
The only way to fix this would be to get a service engineer to remove the pump and check for a blockage, unless of course you are an experienced electrician or technician and don't mind doing it yourself.
Nov 18, 2009 | GE WBSR3140DW Top Load Washer
My stanton t50 turntable plays too fast even when the pitch fader is at the slowest speed
You need to calibrate your pitch control. This requires a small precision screwdriver (similar to something you would repair eye glasses with). If you look under the turntable where the pitch control is you will find 2 small holes, 1 marked 33 and 1 marked 45. Turn the turntable on and set the pitch control lever to zero pitch. While the turntable is spinning insert the screw driver into the pitch calibration hole under the turntable and twist the potentiometer back and forth until the turntable pitch is zero (I believe clockwise is faster, counterclockwise is slower as you look up from the bottom of the turntable). This is a fine tune adjustment and will not require much turning to adjust the speed (1 or 2 mm's) either way should start to bring you into zero pitch. The platter speed can be verified by the little dots on the rim of the platter. They should appear stationary in strobe light on the power switch when you are at zero pitch. When you are adjusting the speed you will observe the dots on the platter rim spinning clockwise and then counterclockwise as you adjust the fine tuning. Fine tune the speed until the dots appear stationary and you will be back to zero pitch. You have to adjust the turntable at both speeds 33 and 45 using the correct fine tuning hole under the turntable. My personal experience is it is easiest to do this with 2 people. 1 person to hold the turntable level and running, while the other adjusts the fine tuning. Hope this helps.
Oct 22, 2009 | Stanton T.50 Turntable
Spin/rinse cycle quits
it may be an intermittent door lock switch. i believe on your model when you remove the front access panel you will find a pair of wires in a plug with nothing attached to them on the r/h side where the wire harness runs. when you are in the spin cycle, check with a multimeter for 0 volts across the 2 wires. if you are showing 120 volts, then your door lock is bad. if yours has never been changed it actually has been updated to a new style. costs about $120.00 for the part. instructions should come with revised part
Aug 20, 2009 | Washing Machines
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Washing Machines Logo
Top Speed Washing Machines Experts
Charles T Nevin
Charles T Nevin
 steve
steve
Are you a Speed Washing Machine Expert? Answer questions, earn points and help others
