Display's power supply of my Pandigital 10 is burned out
I dismounted my pandigital 10 PAN-108-b and it is clear that the LCD power board supply some SMD components are burned. Is it possible to buy the spare part? Thank You. Giuseppe De Luca
How do i reset to factory mode if i forgot my pattern
1. Turn the power off and pull the battery out and reinsert it.
2. Hold the Volume Down button.
3. Then press and release the Power button.
4. Wait a minute,the menu appears that allows for Fastbook, Recovery, Clear Storage, and Simlock.
5. Ok,press the Volume Down button to choose Clear Storage.
6. Next,press and release the Power button,Wait for the Pandigital Novel 7 to restart.
7. You will see the two options: Volume Up for YES and Volume Down for NO.
8. If you choose YES, all data will be deleted from your Pandigital Novel 7 and including third-party applications.
9. The Pandigital Novel 7 will reboot to its original data.
10. This time you can restore your backed up data to your phone.
Mar 06, 2015 | PANDIGITAL Novel 7
I have a pandigital 10 tablet and the screen is broke can it be fixed?
Possibly, if you are willing to tackle the job yourself.
The screens are made by a limited number of firms but you will need to get the exact model number which will be on a sticker on the back of the display module.
These are normally attached with a fragile, flat, ribbon cable plugged into the display's connector.
To access this you will need some patience and a few tools.
You will likely find the display for sale on line from multiple vendors.
Look at the video linked below to see if this is something you want to try:
pandigital tablet lcd screen repair Bing Videos
Your 10" tablet may be slightly different but the principle is the same and having it repaired by a profi will likely not be an efficient way to spend your cash.
Feb 03, 2015 | PANDIGITAL Tablets & eReaders
Lost software disk
click on the link here http://www.pandigital.net/Downloads and look to see if the software you need can be downloaded.
Feb 28, 2011 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Where can i get a ownermanual for my pandigital 8 inch digital photo fram
visit www.driverguide.com , sing in , search, download and install all driver that you want, just put in searcher your model and searchit
Aug 06, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Pandigital pan 70-0 progressively got darker. now you can bearly see picture
Hello. your frame has a dial on the side which makes it brighter or darker. Just turn the dial to adjust it. Regards, Joe
Feb 17, 2010 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Can I get a link to an ownersmanual and software for my pandigital pan70-0
I can't find one either and the directions are not clear as to how to run it.
Dec 26, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
I'm told the directory or file canot be created when I try to drag a picture to the pandigital folder even though I've already copied about a 100 images using the same method.
I have a Pandigital too and although I don't think the users guide mentions it (major oversight on their part), the root directory on this thing can only hold a limited # of files/folders (mine is limited to 108) If I understant it correctly, it's due to the fact that the pandigital uses a FAT (file allocation table) storage method - not that the reason matters. The solution is: make folders in the root directory (you could have up to 108 folders on my pandigital) and I believe each subfolder can have an unlimited number of files in it. I just call my subfolders "Dec 2009 additions, Jan 2010 additions, etc). The Pandigital will randomly cycle thru files in each of these subfolders just as if they were in the root directory. Hope this helps.
Dec 25, 2009 | PANDIGITAL 7-Inch Digital Photo Frame with...
I lost my manuel is there a downloadi can get
i have lost my manuel for epsilon1.3 digital camera is it possible to get another please
Nov 17, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Pan digital 7 frame screen goes white
Removing the internal battery will clear all settings. I have done this on two different versions of the Pandigital frames (seems to be a very common issue) and it has corrected the issue instantly both times.
Good luck.
Sep 09, 2008 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
Televison & Video Logo
Top Televison & Video Experts
