The LCD power supply board is in failure.
Some SMD components of the internal board are burned. Spare parte are available? Thank You. Giuseppe De Luca Italy
  • Televison & ... Master
  • 722 Answers
Hi Giuseppe,
Better go for a new power supply board. Burnt SMDs are hard to get. Good Luck
Posted on Apr 12, 2015
What's the most likely problem with my 50" LG 50LN5100 LED LCD TV. The standby light illuminates when plugged-in but the screen doesn't come on nor is there any sound when the TV is turned on.
Thunderstorm over the coax or /and the power supply measure the power supply by a defect cannot be measured anymore over an analog hand adjustable power Variac transformer from 0 to 240 volt. because a protection can be given by a defect t-con board (as suggestion) but the variac its good to bypass/ overhaul the build-in safety protection circuit inside the power supply board then sometime if there else are broken or bad components hard to find they can be sometimes intentional burning out or become warmer by twist the variac power slowly up from of zero volt until the max necessary voltage T-con boards that can have a problem with smd components sometimes they can burning out the defects but its only to do if there is no equipment to measure repair or nothing was to find without a service manual or other optical defects , an short-circuit tuner also by thunderstorm sometimes only the little ceramic capacitors what hangs to earth (chassis) if the thunder energy was coming over the antenna coax cable. the power supply can stand in a safe protection mode. then a refurbished board somewhere can be necessary that will give a reset to release the protection mode in the power supply.. Thunderstorm can be strange and much different and i have had 2 times repairing when there was only 1 ceramic short-circuit ceramic capacitor to find thats was with one leg is( on cold-earth) on the chassis. as the one and only defect component. A time in a TV and 1 time in a radio , sometimes its realy strange but comes it over the power supply its hard to find because of more recurring complaints if partial repair in smd circuits. hard to do without necessary tools.
Jul 26, 2017 | LG Televison & Video
Sceptre X505BV no power
Could be an open internal fuse or power supply failure
Jun 22, 2017 | Sceptre Televison & Video
My rca 50 inch tv wouldnt turn oon
Jan 14, 2017 | RCA Televison & Video
TV will not power on at all. Is there a fuse or circuit breaker readily available.Sony KDL 46W4100 7yrs old Flat Panel LCD
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Dec 24, 2015 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
I have an LG that just started smoking and smelt like burning wires. Anyone hear of this
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 14, 2015 | LG 37 37LK450 37 LCD TV
How do i fix power on off failure on a Philips plasma model # 42PFP5332D/37
Fault to the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Jul 09, 2015 | Philips Televison & Video
WHATS WRONG WITH MY TV? WHEN I PLUG IT IN IT SMELLS LIKE SOMETHINGS BURNING AND WONT TURN ON
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
May 12, 2015 | Vizio E420VO 42 in. LCD HDTV
LG RZ32LZ55
There could be two possible failures:
1. The backlights are defective (not a common failure for a 14 months old LCD) or the backlights driver/inverter is defective.
2. Power supply failure(very common failure on LCDs) will cause the symptoms you described.
May 22, 2008 | LG RZ-20LA70 20 in. LCD Television
No picture
Bad news if you see burned parts the board is a gonner. SMD and very difficult to repair. most time a replacement is the only repair. The board you are looking at is probably the inverter board. the inverter drives the back lights on the lcd display. Some of these boards can be costly. on some of these sets they use combo boards * ie signal and digital and power supply all on one board
Feb 20, 2008 | Audiovox VE920 9" ULTRA-SLIM DROP-DOWN LCD...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
