Question about Biostar G31-M7 TE Motherboard
Slow my pc usb copy and send
Help me my problems
    Brigadier General:
  • Biostar Master
  • 3,400 Answers
Copying speed is goin slow down
Try pluggin it into a different USb connection, you may have plugged it into a USB 1 connection, it will be faster on a USB2 connection.
Dec 20, 2013 | Western Digital Computers & Internet
Very slow transfer to Kingston 8GB datatraveler
HI,
- Check if your PC is running at its maximum efficiency
- Close all side processes that are not of any use to you. This can be done by pressing :Ctrl+Shift+Esc and then going to processes. In there only close the processes that are under your user name and are of no use. NOTE: DON'T CLOSE "EXPLORER.EXE". This will free a sizeable amount of your RAM, making your PC generally faster.
- While copying anything, avoid multi-tasking as that will simply slow down your PC, causing a delay in the copying.
IF NONE OF THIS WORKS, then create a back-up of all the software in your Pen-Drive and then format it.
This should just about do it.
If still the problem persists, go to your dealer- your pen-drive must be in its warranty period.
Sep 30, 2008 | Electronics - Others
Western digital 1T external hard drive is taking way to long to copy files off my desktop. I have erased and formatted the hard drive and its still way to slow. It takes about 25 minutes to copy a 1...
Make sure that your PC supports USB 2.0, which is high speed data interface. Look for any such option in BIOS settings of PC and if available, enable it. On systems which do not support USB 2.0 interface, the data transfer is very low. You may search google for your PC Specifications and USB Support available.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
May 31, 2011 | Computers & Internet
Unable to download themes from pc to my phone
To download a theme from a PC to your phone you need either of these: bluetooth or usb cable that can connect you to your PC, For bluetooth do the following:
1. Go to where the theme is located on the PC.
2. Right click on the theme.
3. And click on send to, under send to, you will see bluetooth device. then it will start sending to your phone.
For usb device do the following:
1. connect your usb to the PC and the phone.
2. go to where the theme is located.
3. then copy the theme.
4. open where the phone is located and paste the theme there, thats all.
I hope this helps?
Thanks.
Feb 24, 2011 | Nokia Cell Phones
How do i copy my pc folders into cruzer usb 2.0 flask drive
Insert USB drive into your USB ports
It should be recognised as an external drive
Go to the folders on the PC that you want to copy
Select them and Right mouse click and copy
Open the USB drive and right mouse click and Paste
Jan 16, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I got the Samsung A877 Impression and i wanted to know how to put music from my computer on it ... it came with a usb cord but that doesnt seem to want to work with my computer so what do i do ???
you can copy music files in two ways:
1) Send via USB
a) Install the Samsung PC Suite (driver) in your PC/Laptop.
b) Connect the device with the PC/Laptop via the USB cable got.
The PC suite will act as an interface for connecting the mobile to the PC. Use original USB cable for faster & efficient data transfer.
c) The PC suite will give an interface for copying the music files to the mobile, Or, you can directly copy files by accessing the extra drive shown on the MyComputer which denotes the mobile device's memory.
2) Send via Bluetooth
If you have an active bluetooth device available in your PC/Laptop then just send files to the mobile after searching the mobile.
Regards
Vineeth K.
Aug 05, 2010 | Samsung Cell Phones
I have A7N266-VM mother bord and i am using 512+256 ram but my pc is very slow and usb copying too slow plz help me
Hi, ideally today you require a minimum of 1G of memory. Also perform a virus scan and malware scan, as your computer could be infected causing it to run slow.
Hope this helps
Jul 04, 2010 | ASUS A7N266-VM Motherboard
I cannot transfer video and pics from my lg AD6335 to my PC, HELP.
hello,this is so easy as far as you follow the steps below.
1.get your lg usb cord
2.connect it to the phone and also to the usb port of the PC
3.after this is connected the PC will now automatically pair with the LG PHONE
4.you then click on the videos or songs you want to send on the mobile phone,or you can also mark all the pictures first and then you do the same thing to the videos,then yuo click on copy and this will copy all marked pics and videos to the system.
after you are through with the copying you then disconnect the usb by removing it from the back of the PC and also take it off from the phone.
kindly rate this solution if it's helpful
take care.
Apr 18, 2010 | Cell Phones
My pendrive's copying speed is very slow. its capacty is 8 GB. whn i connect pen drive to the PC its get lots time rather then normal time. and when i copying some data its gets slow.
format the pen drive after taking the backup and then defragmented it you will get smooth work in your pen drive. If not so fast after defragmentation then check your computer configuration and its space may be it is due to your computer is slow you con check whether your pen drive is ok or not by connecting it to any other good pc. good luck
And please vote me and rate me..
Jan 04, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My pentium iii desktop pc has 256 RAM . though it is very slow.copy -paste works very slow in 2gb flash drive.
Maybe your computer is using USB 1.1 that has slower data transfer than USB 2.0, buy a new PCI USB 2.0 controller so you can transfer your files faster
Jun 09, 2009 | Computers & Internet
Biostar G31-M7 TE Motherboard Logo
61 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Matthew Spark
Matthew Spark
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
