Question about Exercise & Fitness
Manual for rowing machine - Exercise & Fitness
I NEED AN OPERATORS MANUAL FOR M1 HIRISE WATERROWER..
Good Afternoon, Fit4Ministry:
I found a manual for your Hi-rise, 95 pages of it! Go here to print or view the PDF:
http://www.waterrower.biz/service/service_manual/manual.pdf
Happy rowing!
Chr
Feb 03, 2011 | Water Rower Waterrower Hirise Rowing...
Directions to assemble needed!
You May have to Body Solid service for a copy of the assembly manual it looks like the PDF format has gone by by here is their PH #1-800-5563113 Ext 520 or e mail them @ service@bodysolid.com
Jun 10, 2010 | Powerline Smith Machine - Optional Pec Dec...
I need a manual for a Proteus pmr 3000 rowing machine
Go to www.proteusfitness.com click on user's manual then click on proteus go to rower click on it you'll find your manual
May 15, 2010 | Exercise & Fitness
Display screen doesn
I had the same problem here,,,
This was my friend rowing that we received as a "gift" (he wasn't using it anymore) and the LCD display stop working.
Without the user manual, I decided to remove the side panel and by doing so the LCD panel pop out showing the source of the problem...
The AA battery simply felt off inside the case.
So my guess is that either your battery felt off or is dead.
So here're the steps...
1. remove the LCD panel (use a flat screwdriver if needed)
2. if there's no battery, it is probably inside the assembly. You can try to retreive it by removing the 7 screws on one side or simply leave the battery if it's not interfering with the rowing mechanics.
3. if there's a battery, it's probably dead. Change it!
Apr 02, 2010 | RTO Lifespan RW1000 Rowing Machine
Maintenance
Rowing Machine Kadett Rowing Machine CTGID0 maintenance
Dec 01, 2008 | Kettler Rowing Machine Kadett Rowing...
Exercise & Fitness Logo
381 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
