Question about Toshiba Satellite C55-a5249 15.6" Led Notebook - Intel Celeron 1037u 1
Why wont the fan shut off on my pc less than a year old
    Top Expert:
  • Toshiba Master
  • 4,837 Answers
Some fans stay on,,or if the pc is getting hot it will stay on.
Posted on Apr 12, 2015
My cuisinart cbc 1600 wont stay on its shows erl on the screen and shuts off .. what is this problem and what can do to fix it
There's a three year warranty on this unit. If it's less that 3-years old, contact Cuisinart for a repair or replacement.
Jun 04, 2016 | Cuisinart Coffee Makers & Espresso...
I have a 4 year old TouchSmart IQ770 Desktop pc. It will Shut down after a minute or two, even if the fan is working and the system is cooled down with extra fan from the outside as well. The system will...
my first idea is thermal paste between processor and cooler. Try to replace it.I got some pc which shutdown after similar time, and the reason wast old paste.
Oct 16, 2011 | HP TouchSmart IQ770 PC Desktop
My computer just went belly up! It is a reconditioned IBM ThinkCenter, a little over 2 years old. It was running normally and then all hell broke lose, cooling fan went berserk sounding like a hair dryer...
Since your PC is two years old its recommended to check your computers hardware check your cooling fan
specially CPU cooling fan if that fan is broken your pc wont work and be careful turning on your PC again and again will burn the processor
Aug 04, 2011 | Computers & Internet
The compressor will run at times, but the condenser fan doesn't start and the unit shuts off on either high pressure or the compressor overheats. Why doesn't the fan start with the compressor? The unit is...
IF UIT IS A YEAR OR LESS OLD YOU ARE BETTER OFF CONTACTING THE MANUFACTURER, SINCE THE UNIT HAS WARRANTY FOR PARTS AND LABOR DURING THE FIRST YEAR THEY WILL COVER ALLSO THE FREIGHT COST.
CALL THEM 858-566-7473
Mar 16, 2011 | Breezaire WKE 6000 Wine Cooler
I have a new belling b170f and have just turned it on however the fan at the back wont turn off. how long would I expect the fan to run. The oven has not even been hot yet
If its less than a year old then call belling as it sounds like the thermostat for the cooling fan is faulty. Its designed to cut the cooling fan in at around 65 degrees celsius to protect electronics.
Mar 02, 2011 | Ovens
Acer Aspire 7520, running windows Vista, keeps overheating and shutting down. It is fairly new - less than a year old. Does not run for much more than 20 minutes before shutting off. It was purchased in...
Sounds like there is dust where the cpu fan is and its blocking the ventilation path in the laptop. If you can take apart the laptop to expose the fan, I would make sure the fan is free of debris. Clogged CPU fans will cause the laptop to overheat cause the air has nowhere to go.
If you do that and the laptop is still overheating then the motherboard is going bad unless your not using the correct charger for it. If you use a charger that puts out more voltage then whats needed then that could cause the laptop to overheat so you might need a new charger.
Apr 15, 2010 | Acer Aspire 7520-5185 Laptop
Inspiron 531 freezes
You have to do some maintenance cleaning and check up. Both hardware and software. As this age usually two years.One common failure is the harddrive. You should get some backup procedure. As for software you may do the following. 1. Registry cleaning (Ccleaner is good but be careful also) 2. Application cleaning, uninstalling those program not needed in the system. 3. Log and history cleaning. 4. Defrag is good. 5. And virus scanning it also one of the major cause of system freezes. 6. And unloading some files (back it up then unload) As for hardware. You may do some dusting or reseating. Usually the CPU fans and system fans and its airways.
Jun 08, 2009 | Dell Inspiron 530 Desktop Computer
Spilled liquid in laptop; wont power up
Gennerally, this is a motherboad replacement at a minimum, often many other components are damaged too. If the system is 4 or 5 years old, it may be too old to be econmically repairable
Apr 06, 2009 | Dell Vostro 1000 Notebook
Electric furnace/heater pump/fan unit won't shut off
There are dip switches on the main board.. When you remove the lower panel on the air handler there are instructions to where the dip switches should be for your units fan control. if the switches are in the correct configuration.. The Thermostat may be malfunctioning or not wired properly. and last.. and most expensive.. the motherboard may also be failing.
Jan 09, 2009 | Heating & Cooling
Toshiba Satellite C55-a5249 15.6" Led Notebook - Intel Celeron 1037u 1 Logo
52 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
