Question about Dayton Wire Wheels Dayton Motor, 3-Ph, 5hp, 1750, 208-230/460, Eff 89.5 - 4GZA4
Motor attached to a table saw. It runs for a short time and trips the breaker. Is there a wiring diagram and what readings should I be getting for continuity between windings ?
Circuit breaker trips out
What is the rating of the breaker? Is this enough to run the saw? If this is ok, has the motor become damaged or has the blade got dirt or wood dust slowing it down?
Jul 25, 2014 | Hitachi C10FR 10" Job-Site Table Saw 15...
Table saw keeps tripping breaker
May have a brush in the motor that's hanging up or worn may try
replacing the brushes
Feb 07, 2014 | Saws
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
10yr old table saw smells hot and trips breaker
Maybe, but first rule out several other things. Has the saw been recently overloaded - heavy cuts with a dull blade? You may have a partially burnt-out motor (which means the insulation on the wire in the windings has partially melted.) Has it been used recently or used now with an extension cord or to an outlet wired with 15 ga wire? Is the saw arbor hard to turn by hand (with the belt removed)? Does the motor overheat with no load (remove the belt and let it run for 10 minutes)? Try running the saw with the belt on, but not cutting for 10 minutes.
Dec 10, 2012 | Craftsman 10" Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
I need the wiring diagram for my 10 table saw, I disconnected the motor and the power supp. without marking it first and now i don't know which wire goes where, please help!!
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
Nov 02, 2009 | Craftsman 10" Table Saw
Delta table saw motor trips breaker
The motor needs a new start capacitor.
Apr 09, 2009 | Saws
Delta Radial arm saw 33-990 tripping circuit breaker
More than likely motor but try this , if you have a wrap around amp probe or can borrow one or purchase a cheap one place the amp probe around the positive wire connected to panel breaker ,with meter on proper scale ,start saw and read probe current , if cap bad current will be high and stay until breaker trips , if motor will start high on start ,then low then ,very high and breaker will trip , be careful in panel working around live circuits , the reason it reads this way is because as the motor warms the laminates it the armature separate and cause the increase in current to spike ,if cap bad never gets to speed and has high current draw constantly , to verify cap(1) remove from circuit (2)place a screw driver across terminals to release any charge (3), then take ohm meter on ohms place meter leads on terminals one on each terminal at same time meter will rise and fall back(4) reverse leads and should rise and fall as before if it does this it is more than likely good a lot of electrical reasons for this but this will tell you what you wanted to know , good luck
Dec 08, 2008 | Saws
On/off switch table saw
It sounds like you are wiring the switch wrong. Give me the model # and I will look for a wiring diagram for you.
Nov 02, 2008 | Saws
Dayton Wire Wheels Dayton Motor, 3-Ph, 5hp, 1750, 208-230/460, Eff 89.5 - 4GZA4 Logo
Top Dayton Wire Wheels Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Dayton Wire Wheels Tool and Hardware - Other Expert? Answer questions, earn points and help others
