Question about Hitachi Televison & Video
Looking for a replacement stand ,existing one lost when tv had been wall mounted.
  • 36 Answers
Try e spares on the internet
have most parts
Posted on Jun 19, 2016
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
  • 34 Answers
SOURCE: taking off stand from LG tv to mount on wall
I work on TVs and the amount of screws in the back is crazy.
find a place to lay the tv down on the screen, use some pads and a blanket to prevent scratching or cracking screen. your couch or bed may be a good choice, but make sure it is stable. let the stand hang over the edge with no weight on it. now look for 6-8 screws per per leg of the base. depending on the size of your tv. these are usually the larger screws on the tv and attached to the frame of the TV. remove these screws in the base and slide the base out.
your manual should also have a brief description of base removal as well. dont worry about taking out the wrong screws, you can put them back in it is not the right screw. with tv on its face, no parts will fall out. hope this helps.
Posted on Apr 08, 2009
SOURCE: Lost screws for for my 32" polaroid LCD TV stand
M5 X 18MM
Posted on Aug 19, 2009
SOURCE: Wall mounting Panasonic Viera 32" tv
There's a little more elaboration required on the above post...You need to remember that the base has two long pins that go up into the TV. These pins are held in by two screws each. The screws are on each side of the TV (two vertical inline screws, inside a small inset section). Remove all four screws and the TV will come up off the base. Pull it straight and gently, but firmly, to unseat it from the pins.
Posted on Dec 28, 2009
SOURCE: how do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Posted on Feb 07, 2010
I recently bought a tv from someone. They lost the stand screws as they had the tv wall mounted. I do not know where he bought it from. How do I get the screws I need for the stand?
bring stand to hardware store or place that carries screws bolts and match up or if have paperwork look up specs and buy them
Jul 11, 2017 | Televison & Video
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
Set up for lg cs570
Some stands come with a mount that looks like a wall mount, ready to mount to the TV. If not then use the table top stand that came with the TV
Jan 02, 2014 | LG 42" Cs570 Series Black Flat Panel Lcd...
Tevion19" TV/DVD Combo
Go to a Walmart or other appliance store where alot of TVs are sold
Jan 13, 2013 | Televison & Video
Hi, we have just bought a second hand Hitachi Hi Plasma TV Model PD1, 42PMA400A. We have a wall bracket but what we'd eally like is a stand ... the base plate and two stems that go into the bottom of...
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there from someone who has their TV mounted to the wall and is no longer using it. These are normally fairly heavy and bulky items, so Ebay purchase prices and shipping costs can vary widely.
I did not see any for your exact model of TV available there when I looked, but the online selection changes daily, so you can always keep checking back. Just search on Ebay for 'HITACHI TV STAND' or 'HITACHI TV BASE' and you will see a wide variety of them available for different Hitachi TV models as well as what the average price for them is.
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Hitachi Televison & Video
I need the base stand for my tv cus been wall mounted and now need it on stand and i lost it
Not all Philips tv's will use the same stand. First, look on the back of the set for the model number. You can purchase most television parts, including stands and base assembly at http://www.partstore.com/
Jul 29, 2009 | Philips Televison & Video
Lost TV mount hooks/fasteners
I am getting rid of my sampo.  I am willing to sell the tv brackets or the stand or the wall mount as well.
Jan 22, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Stand
You would need an actual wall mount bracket for your TV. Here is a link that you should be able to find what your looking for.
http://www.mountsandmore.com/TV-Mounts-C135.html?refid=OV81.tv+wall+mount
Mar 12, 2008 | Televison & Video
Televison & Video Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
