Question about Garden
The lid is not opening, i.e. cant refill the water
    Top Expert:
  • 10,875 Answers
Put some power into it,let off pressure first
Posted on Apr 12, 2015
Testimonial: "thanx, but it is empty now,"
Why is the cistern noisy when refilling
remove lid and look where refill hose is located should be attached and in fill tube [center tube ] if it is than your toilet s noise is normal --you can knock it down a little by turning down the water pressure[turn the external valve on the water line going into toilet ] turn it a little this will also slow refill time as well --and as to ultra quiet that s for the flush mode not the refill mode
May 09, 2014 | Caroma toilet - water saving Sydney Low...
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
THE WATER IS BOILING IN A WATER BOTTLE
This can be caused by a defective radiator cap or improper coolant mix, it should be 50/50.
Jun 27, 2012 | 2008 Ford Ranger
Where do I refill the water windshield for 88 porsche 911
hello there
the water reservoir filler is next to the filler for fuel after you open the lid.In left fender.There should be filler cup(clear plastic)
proporsche
Aug 28, 2011 | 1988 Porsche 911
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
The fill spout doesn't have water coming out of it after flushing. I have to open the tank lid and juggle the little spigot where water is supposed to come out to refill tank after flushing.
You have dirt clogging the fill valve...the best thing to do is replace it with a Fluidmaster 400 valve... this valve is cleanable...
heatman101
Aug 18, 2010 | Home
I accidently put Jet Dry DISHWASHER CLEANER in my rinse agent dispenser and I need to know how to drain it out..help!
if you leave loading draw or lid open and do a hot wash with no detergent water will enter replacing the detergent you will have to do this several times till wash tub runs with clear water then refill with rinse agent.
Feb 16, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dual flush toilet fills up slowly how do i fix
Lift the tank lid off, place it somewhere safe for a moment, and look at what happens: If you're talking about jiggling the handle to get the tank to start to fill with water, then it sounds like the chain or rope is out of adjustment. It can't be TOO TIGHT or the water will leak past your flapper (will cause your dripping noise, tank water level will leak down, causing constant refills), and it cant be TOO LOOSE or the toilet won't flush correctly. Since you didn't mention trouble flushing the toilet, I think that it may be a little too TIGHT. When you jiggle the flush lever-it is supposed to pull a chain or cable to open the flapper at the bottom of the tank. Flush the tank and watch what happens-all the way through to refilling the tank with water and shutting off the water refill valve-Does the flapper get stuck on the chain or something? It is supposed to fall back down to allow the tank to refill after flushing out your toilet. Does the chain look very loose? The dripping sound you described indicates that the flapper is not sealing 100%. The flapper is very easy to replace, you just have to get the adjustment set for when you flush the toilet how sensitive you need it. You amy have to play with it a little bit before you get the adjustment correct.
Hope this helps!
Nov 08, 2009 | Home
How to pour distilled water into an Exide battery
Yes well first of all u hav to check out is refillable battery...
if its refillable then u hav to check out lids and open them with the help of coin and put appropirate quantity of acid...
and make sure its diatilled water not pure pure acid...
Regards
Tawseef
Nov 15, 2007 | IBM Tripp Lite OfficePro 700 (10K1912) UPS...
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
