Question about Freecom ToughDrive 3.0 Mobile Hard Drive 1TB 97711
How can I fix my Freecom Toughdrive 1TB? When I plug in my device, I only see this weird 62.4mb USBDISK and I couldn't see the 1TB drive anymore.
I need help on how to recover my 1TB Freecom Toughdrive 3.0. Suddenly when I plugged in my hard drive to my laptop, I saw this weird USBDISK drive with 62.4mb capacity. I noticed that I couldn't see the 1TB disk anymore, and I haven't done anything that could break this hard drive. Is there a possibility to recover this drive? I don't care if the files will not be restored as long as I can put back the hardrive back to its normal condition. Hope you can help me, I've been sending emails for freecom support but as of now, no one's answering me. This drive is still under warranty but I bought this outside my country and claiming the warranty is almost impossible. Thanks a lot!
  • 22 Answers
SOURCE: How do you retrieve deleted files on the freecom?
you can use http://ntfsundelete.com/ -FREE
Posted on Apr 01, 2010
riceski
  • 1851 Answers
SOURCE: USB not recognized
if the usb ur using is 1.0 - it can read it - get a 2.0 external unit and you're good to go.
Posted on May 02, 2010
  • 5128 Answers
SOURCE: I need to intall a
Unfortunately, the company only supported: OS: Windows 2000 / XP / Vista / Mac OS X v10.3 or higher and Time Machine (OS X v 10.5 Leopard) compatible, for their USB hard drives.
You would need someone to write a driver for you or to connect to a computer with a supported OS.
I wish that I could be of more help.
Posted on Nov 13, 2010
bronk50
  • 27725 Answers
SOURCE: what should i do when my freecom toughdrive does not recognize of any computer
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Posted on Feb 20, 2012
SOURCE: My Freecom 1.5TB Mg EHD is not working (dropped), does anyone know how to get into the EHD to check for loose connection (no screws and definite
you can do that if you wish but a data recovery specialist has the tools to do this cleanly look for one nearby and let them know the situation you will NOT be happy doing this yourself.
Posted on May 21, 2012
When turned on the harddrive does not make its normal startup noise and worse; the computer does not see the harddrive anymore! The blue light on the front pannel is lit though. Help...
Hi
Check all cable connections in firmly & correct way round, from motherboard & hard drive. Check in bios, make sure hard drive setting is set to Auto. Place you hand on the hard drive to feel vibration. Hard drive could bd faulty. Western Digital are renound for it.
Jun 26, 2014 | Freecom ToughDrive 400 GB USB 2.0 Hard...
Export saved emails from toughdrive, import to my laptop
A little more information. What email program are you using Outlook express? Outlook?
If you are using outlook express open it. go to File / Import / Messages.
select the type of program the emails are in when you saved them to the external harddrive.
click next select import mail from OE6 or whichever you had from above. and click ok.  then click browse. and find the drive the email was saved on. then click the folder you have the emails saved in. and click ok. ( it may be easier to save the email folder to your desktop of your computer and just browse to your desktop).
click next select your folder you want the emails to go to and finish the emails will be imported
Oct 26, 2007 | Freecom (24358) 160 GB Network Hard Drive
Computer doesn't recognise hardrive
It may seem obvious, but did you try a different USB port? Did you try a different computer? and did you try a different cable/cables?
Oct 03, 2012 | Freecom ToughDrive external hard drive -...
Used drive once, now computer doesn't see it
try restarting computer with drive plugged into usb but no power on drive
once computer is all on, then power on the hard drive
May 24, 2012 | Freecom Xs External Usb Hard Drive 1tb
I accidentally plugged in my 19v toshiba laptop adapter to my 16v 1tb external hard drive it started up but then i plugged it out soon is it possible that the hard drive will work or is it dead, if no
The electronics in the hard drive is damaged and cannot be repaired by us mortals.
There are companies that can recover data from damaged hard drives BUT it will cost you an arm and a leg for their services.
May 12, 2012 | Western Digital WD My Book Essential 1TB,...
What should i do when my freecom toughdrive does not recognize of any computer
hope this helps
Feb 19, 2012 | Freecom Computers & Internet
HD suddenly asks for Password, never set one!
The password-protection program is designed to protect your files, so that if in case your HD is stolen, any important files will remain intact in the HD.
You have to refer to the use manual of the HD and look for the default password. Since you mentioned that you never set any passwords, it means that the HD is still using the default or manufacturer's password or code. Check the manual and you should find it there.
Or you may want to contact the tech support of the manufacturer and see if they could give you the default password.
Thank you and good luck!
Jul 12, 2010 | Computers & Internet
I recently bought a Freecom 1TB hard drive. It
Is this a SATA drive and what operating system is loaded on it? .
you may have to insert the installation disk to reset the password.
There is a Linux program on the internet to reset the password to default but there is no guarantee to this. This is for Windows XP
2. You can also get some one with a Linux box to view and backup your data on another hard drive but the PC will have to be compatible to accommodate the hard drive capacity.
3. Try not entering a password at all when in the password/ user screen "hit enter"
Feb 03, 2010 | Freecom (24358) 160 GB Network Hard Drive
Window 7 and Freecom Touchdrive
May be it does not have a compatible driver for the drive. Launch the Add/Hardware wizard and use it to search for a driver on the internet. If a driver is available windows will download and install it.These driver issues usually happen with new operating systems. Even Vista had these problems when it first came out.
Dec 05, 2009 | Microsoft Computers & Internet
No response at all from laptop regarding my toughdrive 160GB
Your files are safe on the HDD, the trick to retrieve.
You should have backup at the end of your sessions
If you have the setup disc, reinsert and run!
Nov 13, 2009 | Freecom Portable II External DVD Drive
Freecom ToughDrive 3.0 Mobile Hard Drive 1TB 97711 Logo
62 people viewed this question
Top Freecom Computers & Internet Experts
callhow
Level 1 Expert
John Anderson
John Anderson
Are you a Freecom Computer and Internet Expert? Answer questions, earn points and help others
