Neff W4380X1 Front Load Washer Logo
B
Ben smith Posted on Apr 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our washing machine always starts on rinse and previously you could put it on a second cycle which would go to wash option but now it just does rinse and not wash. Please help!
Glenn
Level 3:
Master:
  • Master 591 Answers
  • Posted on Apr 12, 2015
Glenn
Master
Level 3:
Master:
Answers
591
Questions
Helped
171643
Points
6976
Nothing we can do about it from here.
Call an appliance repairman to come out and fix it.
2answers
My roper top loading machine washes but will not advance to rinse it fills up but drains immediately after.
Please power cycle your washer (ie unplug power for 2 minutes before powering on again). Then, you can move your dial counterclockwise (or opposite the direction that you currently turn your cycle-setting dial) by 90 degrees. Then, attempt a full cycle again. This should help somewhat reset your cycle functions so that it works properly.
Thank you.
I have a Kenmore top load, high efficiency, low water washer. How to get to rinse and spin ?
May be a bad door switch. Washers usually let you open the machine (top load) while in wash, but not for rinse and spin because of the high speed. If the door switch is bad, it may think the door is always open and therefore wont go past the wash cycle.
2answers
My LG washer stops in rinse cycle. Have to unplug restart and set to spin only to finish.
If the washing machine does stop at the rinsing cycle and will not continue , It could have something to do with the machine's timer not working correctly . If the timer is broken or is not working it will have to be replaced to make sure that the machine can be able to run through the rinse cycle again.
I have a ken more elite top load washer. How do I reset the washer to start a fresh cycle? It's stuck on rinse and won't finish previous cycle.
pull the start button out for to put on the on position, then unplug it for a few minutes then plug back in, or u can try opening and closing the lid slightly 6 times with a 12 second period, should reset it
Why does my whirlpool model WTW57ESVW1 starts to rinse toward the end of the spin cycle?
The rinse is supposed to start during the spin...it's what removes most of the soap from your clothing! The spin forces the water through the clothes, flushing all but a small amount of the detergent away. The rinse cycle itself is more to remove solid debris that may have become trapped in the folds of cloth. It does so by floating and agitating the clothes.
The quick wash cycle is only for things that aren't soiled much, that you need to be done fast. It's not for everyday washing, just for things that maybe need no more than a freshening up. It makes it faster by cutting corners.
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
In my hotpoint ultima WMD942P washing machine's softner compartment i always find water at the end of the cycle. its a new machine.
This is completely normal, the machine puts water into this chamber during the rinse cycle to wash the softener into the machine.
Water softener goes in at wash cycle rather than rinse cycle
if it has to go in the rinse,,this means you have to put it in the fabric softner compartment of the dispencer,,,also do not fill pass mark fill line in dispencer or it will sphion down by itself before time..onthejob
7helpful
3answers
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Top Neff Washing Machines Experts
ZJ Limited
ZJ Limited
vince
ADMIN Eric
ADMIN Eric
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
