Question about The Clothing Accessories
I'm in need of Ray Ban PS8 W2175 right temple. Could anyone help, please? Or the whole frame, just to use the lens in good condition
    Sergeant:
  • 166 Answers
Might be cheaper to buy a new pair http://ebay.to/1FAbUCc
Posted on Apr 12, 2015
SERIAL NUMBER 571232
Whats the Question. Here are the specs of what I think you are asking about.
SKU: CU-334E544C39 Smith & Wesson Safety Glasses 19855 This contoured design is complete with rubber grip temples for a more secure fit. Safety Glasses, Series Smith & Wesson(R) 38 Special, Gender Unisex, Lens Color Blue Mirror, Polarized Lens No, Lens Coating Scratch-Resistant, No Foam Lined, Eyewear Frame Design Wraparound, Eyewear Frame Style Full-Frame, Frame Color Chrome, Eyewear Size Universal, Frame Material Nylon, Lens Material Polycarbonate, Temple Color Chrome, Temple Style Ratchet Hinge, Photochromatic Lens No, Metal Detectable No, X-Ray Detectable No, UV Protection 99.99 Percent UVA/UVB, Standards ANSI Z87.1+ 2010 https://www.shop.com/Smith+Wesson+Safety+Glasses+19855-1579966230-p+.xhtml?sourceid=298&gclid=Cj0KCQiAkNfSBRCSARIsAL-u3X-48mMYWeuydAxWgqybEmPqIugmO3kiTwjX1SB8EjwLqAnzQMYw76oaAuwPEALw_wcB#product-details
Jan 23, 2016 | Jackson Smith & Wesson 38 Special Safety...
Tip
How to Repair Ray-Ban Sunglasses. ?Replace a lost or missing screw in your...
How to Repair Ray-Ban Sunglasses.<br />&bull;Replace a lost or missing screw in your Ray-Ban sunglasses with a small piece of wire. Push the earpiece back into place on the sunglasses and gently wiggle a small piece of wire through the screw hole. Pull the wire through the opposite end and push it back through. Push the wire through at least three times and use your pliers to twist together the ends.<br />Fill a small bowl with warm water and set your sunglasses in it. This is a quick trick for fixing loose frames. The warm water heats up the frames, making it possible to reshape the glasses yourself. Remove the sunglasses after a few minutes and gently bend the frames.<br />Hold the Ray-Ban sunglasses in one hand to replace a lens that popped out. Turn the sunglasses over, so that the front faces down and place the lens onto the back. Gently press down with your other hand, until the lens pops back into place.<br />Use an eyeglass repair kit to replace any missing screws. The kits come with several small screws and a tiny screwdriver. Line up the screw to the proper hole and gently screw into place. If the screw won't go in, it means that your screw hole is stripped and you need to use the wire method.<br />Seal broken parts with instant glue. For broken frames, apply a thin layer of glue to one side and push the broken piece back into place. Hold until the glue dries. Instant glue also fixes lenses for wireless frames. Apply a layer of glue to the bottom of the top piece and push the lens in place.
on Nov 07, 2010 | Clothing Accessories
I need a replacement arm for rb2030 ps8 w2175
I'm in need of Ray Ban PS8 W2175 right temple as well.
(Or the whole frame, just to use the lens in good condition)
Feb 05, 2014 | Ray-Ban RB 2030 Sunglasses
The correct serial number on ray ban
look at the box your Ray-Bans came in. There should be a recycling logo, as well as a semi-permanent sticker on the box, including the serial number, manufacturer and distributor details, lens and frame type, and the model number of your specific style of sunglasses. If this sticker is missing, the sunglasses in the box are probably not genuine.
Jun 11, 2012 | Ray-Ban Clothing Accessories
Ray ban rb4105 folding wayfarers the grey hinge on the brdige broke. the frame is alright so I think i just need to get that 1 part replaced.
please help me!!!!!i cant find a spare part for the hinge on the bridge of my wayfarer folding...what can i do???
Sep 06, 2011 | Ray-Ban RB 4105 Sunglasses
I want to know what sizes is the frame of the versace VE 4157, as in the outer edges of the frame horizontally, i reference whit the width of the face,
Frame Size: 65MM 17MM 125MM
Typically there will be three standard numbers imprinted on one of the temples or the bridge, indicating respectively the sizes of three frame parts. All sizes are marked in millimeter.
1. Lens size: The first number 65 represents the lens size, which is also called eye size or lens width. Lens width is the most exact name of this size, describing precisely the distance between the vertical sides of a rectangle containing the lens shape. It is important to differentiate it from lens height. A large lens for a big guy usually has big sizes at both dimensions.
2. Bridge length: The second number 17 represents the bridge size. Other sayings include bridge length and bridge width. In detail, it is the minimum horizontal distance between the nasal surfaces of the rims. This size varies only slightly because people's noses will hardly differ significantly. When the frame is sitting too high on the face, it is necessary to increase this bridge size. In opposite, a shorter bridge is needed when the frame sits too low on the face.
3. Arm length: The third number 1125 describes the length of an arm or temple. This is the whole length of a temple, consisting of the length to the bend and the length of the drop.
Jul 18, 2011 | Versace VE 4157 Sunglasses
How do you find out if Rayban Aviator are genuine or false? I have a couple of tips, but I wanted to know if there was some extra thing to check. Please do not tell me any obvious stuff like "go to...
These are the markings to check for.
Older Models made by Baush and Loma.
-Ray Ban B&L Made in the USA across the top part of the upper bridge.
-Size Markings on the paddles. (Only if they were not changed out, and are not the wrap around ear frames)
-Ray Ban white logo on the Right eye Lens. (Left if you are looking at the glasses) this should not come off easily like, with a cleaning cloth.
-B&L etched in the lenses, many knockoffs will have it painted.
-B&L engraved in the nose guards
Further information needed
Newer Ray Ban's made by Luxottica
-All newer Ray Ban's sold in the U.S.A will be made in Italy.
-Ray Ban Made in Italy under the top bridge
-Made in Ray Ban made in Italy CE on the inside right leg.
-Correct size and model info on the left inside leg.
-R&B etched in the lenses.
-Ray-Ban painted white on the Right Lens (Again won't come off easily)
Applies to both
-Should not have a mix of the above features....common mistake (Example made in USA across the bridge and made in Italy on the leg.)
-If painted, it should be enamel and should not come off easily.
-Hinges should have a distinct shape, not oval, and should not have any "burn" marks on the metal from being fused.
-The paperwork..sometimes called care book. (not the registration card) should be crisp with a professional work. Common fakes are printed with regular or shiny paper, haphazardly folded, sometimes colors will be bleeding, and or the English is full of typos.
-Mispelled words on the protective case if it has one. This should also match with the glasses. Luxottica with Italy made and Baush and Loma with U.S.A.
-Box is beat up or has Asian characters.
-Hinges should move smoothly but should not be loose. (Older/Used may require tightening.)
-Plastic lenses. An easy way to test this is to direct the car A.C. air at the lenses. Glass lenses will cool rather easily will feel cooler to the touch than plastic.
-Have them checked at a local sunglasses place, UV can be tested too. Many cheap priced sunglasses misrepresent the amount of UV that is blocked. Ray Ban's have a good reputation of Blocking that 99-100%
Jan 13, 2011 | Ray-Ban Ray Ban Aviator Sunglasses Metal...
What shape face do aviator sunglasses best suit?
It depends on the aviator type you mean, since you have two: 1. http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3026-Large-Metal-II-Aviator-L2846-16200.html 2.http://www.smartbuyglasses.com/designer-sunglasses/Ray-Ban/Ray-Ban-RB3250-Aviator-OO471-16213.html Both frames would look good on almost everybody, although you should be careful with long faces. In that case, the second frame might not look perfect. In addition, you should ensure that the frame color suits the hair and skin color; a golden frame might look very good on somebody with a tanned skin and black hair, while it would absolutely not suit somebody with a white skin and blonde hair.
Source(s):
Clothing Accessories Logo
682 people viewed this question
Top The Clothing Accessories Experts
ray gallant
deton8 von Splosion
Are you a The Clothing Accessory Expert? Answer questions, earn points and help others
