Question about Water Water Heaters
How do i install this thing? L N And theres another for eathed. This is a panasonic water heater
    Sergeant:
    Champion:
  • 219 Answers
This is not a job for an amature, if u don't know that L=Live & N=Nuetral leave it alone, this is where u pay an electrician a small fee to get it right.
Posted on Apr 12, 2015
    Sergeant:
  • 166 Answers
You take the old one out, carefully observing the steps needed, and the location of all of the parts. Then you put the new one in, being careful to connect everything the same way.
I just got hot water service put in electric has 10amp fuse keeps tripping I need to put 16 amp fuse in only thing is wiring from switchboard to heater 1.5 mm is this an issue
sorry but only a certified electrician can assist you . there are certain laws that must be followed on installation of water heaters
Feb 23, 2017 | Water Water Heaters
Can i use a tankless hw heater to supply my hobart am15 dishmachine
Don't install tankless, because repairs, installation, operation, maintenance, replacement etc are expensive.
And the thing can be unreliable since you are connecting a computer chip and sensors to gas line, water line, electric line, and to a gas burner with vent to outdoors ... and each of these systems has problems on its own without a computer chip that can fail at the first electrical surge.
Otherwise call Rinni for specs.
1-800-621-9419
Ask about the 4 year warranty for residential installation.
Ask about deliming each year.
Ask about exposure to hard water, and water impurities, and water problems. Tankless cannot be exposed to more than 11 grains hardness.
Ask about recommended yearly maintenance requirement.
Ask why there are no service manuals, and how technicians know how to fix the thing without detailed service manuals.
Call around locally and see who services the thing, and ask if there are service problems.
Apr 07, 2013 | Hobart Commercial Equipment Ventless Dish...
We have a reliance sta kleen 805 lp water heater that we installed used and it will not let us go through the start up procedure. i assume its in some kind of lock out mode, it does not respond to hot...
Used, Reliance 805 is power vent gas
10 year old water heater that is newly installed.
Unknown gas control valve.
I'm not a fan of installing old power vent water heaters.
Usually these things are so expensive that old one is only replaced when it fails.
120Volt Outlet must have correct polarity and unit must be grounded between ground prong on cord to manifold tube connected to bottom of gas control valve. Test for continuity with multimeter.
Is this an early FV model with air intake located on bottom?
If air intake is clogged with dust, then combustion chamber overheated and tripped FV system. The older heaters need replacement parts and new gas control valve, or entire heater must be replaced.
Replace gas control valve.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Copy following link for gas control troubleshoot by type of gas control.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Post question on Tank forum with more information about type of air intake and gas control valve and history of water heater
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Oct 25, 2012 | RELIANCE ELECTRIC WATER HEATER
My 606 reliance gas water heater run for 5min and pilot goes out
If the pilot will light and stay lit, then ECO is not tripped, and thermocouple is probably good.
If ECO is tripped, then pilot will have no gas.
Usually if thermocouple is bad or installed incorrectly, the pilot goes out immediately after releasing the pilot knob during lighting.
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
First thing is to clean water heater air intake and get more fresh air to the water heater and see if that solves problem. Combustion of hydrocarbon requires oxygen that must be pulled into the water heater from surrounding rooms. If water heater is closed off, or located in hot attic that is not correctly vented, or house is tightly sealed, or air intake is clogged, then there is not enough oxygen to support combustion.
Next thing to check is color and size of pilot flame.
If color of flame is NOT clear blue, or if flame is weak, then that says the pilot orifice and burner tubes and burner should be removed and cleaned, along with cleaning combustion chamber.
Additional suspects include combination of things, including: , bad gas control valve, low gas pressure, air in gas line, water dripping down vent and putting out pilot, reverse air flow or backdraft down the vent that blows out pilot, damaged burner parts because of exposure to trace chemicals such as bleach and wax.
Open following link to see various images and read resources.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Sep 30, 2011 | Water Heaters
We purchased a new electric hot water heater we installed it on a 220 line and we are not getting no hot water
check with a vom set on high voltage setting. for power... black wire to black wire,, white wire to red wire on heater ground wire to tank ..on 220v there is no neutral like on 110volts..check red reset button under top panel / control push on it resets it,,,
Apr 17, 2011 | Whirlpool Water Heaters
Water is leaking from a whole in the top of the water heater what is the cause
If water heater is leaking out of a hole, then tank is rusted out and needs to be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
First thing is protect yourself.
Tank could rupture.
Turn off power
-Electric heater: turn off circuit breaker
-Gas heater: turn knob from ON to pilot, so pilot light stays lit.
Open bathtub spout on hot side and release pressure.
Now you're save.
When you need hot water, turn heater on for 1 hour, use hot water, then turn heater off again.
You can limp along like this for a while until heater is replaced.
I buy water heaters at Lowes, Ace, Home Depot, Sears.
Look for scratch and dent.
Look for same size that you have now.
manufactured homes require heater that is made for that application.
Propane and natural gas heaters have different burner.
Always offer 10% less than asking price on any water heater.
You need teflon tape, 10" pipe wrench, new flexible water connectors, and a drip pan, and maybe insulation blanket.
Read how to install gas water heater.
To install electric water heater, open link above because some things are same for both gas and electric.
Difference with electric is there is no gas line, and you connect wires same way that they came off.
Feb 04, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Is there alot of problems with bosch aquastar 2400
Bosch has had problems with these heaters for sure. They are the best known thing out there in the market.They are mostly responsible for the bad rap being given to all tankless heaters, but a big part of the problem is installation. They are being sold to homeowners at box stores as DIY kits. These are not units to be homeowner installed, venting and fuel requirements are different from regular heaters and they will not function correctly if improperly installed. I have installed several of the Rannai units over the past few years without any issue whatsoever.
Mar 10, 2009 | Bosch AquaStar Indoor Natural Gas Tankless...
Water Heaters Logo
32 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
