Question about Cooktops
I don't know how to use this at all. I switch it on and set what I think is to 9 on the correct hob, put the pan on but it does nothing
    Sergeant:
  • 166 Answers
1.Download and Read the owners manual.
2. Find someone who knows how to use it and ask them.
3. Might be broken.
4. You may need to call a repairman.
5. use the microwave instead.
Posted on Apr 12, 2015
My 5 ring induction hob works fine but has stopped showing H or h. Is it possible to turn this feature off accidentally or is it a fault?
do not think there is any OFF switch for the HOT indicator .if it all works why even worry about it .
Aug 08, 2015 | Neff Cooktops
Does anyone know more about the error codes F5 / F6 on a Whirlpool/Ikea induction hob Type: PLEAC, Model: 80123766 approx. 7 years old?
Call a Wirlpool dealer and give them the code. They will tell you what the problem is. I think F5 or F6 is the control panel. The last time I went to replace one I was better off purchasing a new stove.
Apr 22, 2015 | Cooktops
I have just moved into a new apartment in France, and we have a 2 ring touch screen hob. There are no instructions or booklets but it says "Schott ceran brandt" on it. It works, as I've worked out how to...
i presume that you have a induction cook top. if so not all pots and pans will work on them. i have never had one but i do know this could be your type of problem. do some research on what pans to use on a induction stove.
Jul 02, 2017 | Cooktops
My Neff T67S76NO hob has a Wok burner problem, I think. The inner ring flames are fine but the outer ring can't be turned above half on before the flames start to go ragged. The more it's turned up th
it sounds to me that u need to reduce pressure although u say pressure is correct try reducing pressure and see what happens i presume u use bottle gas L P G?............in any case the flame shud not ever lift of burner and flame doesn't need to touch pan to cook hope this helps
Jan 07, 2014 | Cooktops
How to unlock a lamona induction hob
Had the same problem, manual says switch on and press + and - buttons at same time then press - to cancel child lock. Kept trying but no luck. Tried same thing with a pan on the hob that I was pressing + key and it worked.
Jan 12, 2013 | Cooktops
Miele KM443. Elements switching on and off every 5 to 7 seconds.
as far i know it is normal if u put at high control after a sec,the sencor control is turn off then a sec again it open coz of the sensor, design the sensor for not overheating the hob.it is normal try to position the control in in not a max position.or the pot u use is exactly in the circle or bigger dont put a small one in the bigger hole of ur elctric hob.tnx
Nov 23, 2008 | Miele 30 in. KM443 Electric Cooktop
PROBLEM WITH HOTPLATES SWICTHING OFF
Sometimes this happens if the pan bottom is not completly flat or is highly polished. Darker, flat pans work best. It sounds as if the safety is cutting off the burner.
May 31, 2008 | Cooktops
Neff 4 ring, ceremic top hob - how do I turn on!!
You press the "on" which is on the left. Press the picture of hob you require and press the up and down for temperature. Then put your pan on the hob and it will work. If you need to adjust the temp you need to remove the pan.
Oct 15, 2007 | Neff 23 in. T1443 Electric Cooktop
Cooktops Logo
115 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
paulcarew
Are you a Cooktop Expert? Answer questions, earn points and help others
