Question about Refrigerators
The evapourator plate inside the fridge keeps icing up
  • Refrigerators Master
  • 5,323 Answers
Fridge freezing up- and no fan or air circulation:
AT TIMES The fan usually stops working due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 13000 ( give or take 150 ohms) ohms is required
Posted on Apr 17, 2015
4 Suggested Answers
  • 90 Answers
SOURCE: Fidge is icing up inside on the rear
Defrost problem, advance into defrost to see if heater comes. If it does replaced timer, if it doesnt you will need to check heater and defrost thermostat.
Posted on Jan 08, 2008
  • 531 Answers
SOURCE: leak - water not evapourating
check your doors may be not clossing (ajar) or check control to high
Posted on Apr 02, 2009
heatman101
  • 43501 Answers
SOURCE: fridge not getting cold
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 03, 2010
My fridge alarm keeps goin off and the inside the fridge is warm
It is very likely the defrost element has failed so it will just ice up in the back where you cannot see. Maybe switch it off for 24 hours and see if a lot of ice melts and then restart.
Jun 02, 2014 | Baumatic BRB2616
Refrigerator leaking
very simple solution there is a drain cup usually in the fridge at the top by the lights or on the back wall make sure it isnt plugged . now the other thing you will need to do if that cup isnt plugged is pull the fridge out from the wall there will be a black or white tube running down your fridge to a tray or a dish on top of the compressor that is your drain it runs over the compressor so the heat can evapourate any water make sure its not plugged and water can run out of the tube . if you go inside the fridge and that drain cup is covered in ice then u have a defrost problem will need a technician to replace either the defrost timer or heating element or your thermastat good luck
Oct 02, 2013 | Whirlpool Refrigerators
How do you stop ice building inside, at the back of fridge model Beko LA87 Larder fridge
It can be 2 things. One is that the thermostat is broken but then it will also freeze your food. The other reason is that it has lost part of its gas charge due to a leak on the system causing the unit not to reach temperature thus not switching of on the thermostat and building ice inside. Normally it is not economically viable to fix the unit.
Oct 06, 2017 | Refrigerators
Icing up in the freezer, loosing cold in the fridge. Sweating down the inside wall between fridge and freezer. Icing up at vegetable drawer.
Pull the fridge our from the wall and vacuum the back wall of it very gently. Also, take the kick plate (just above the floor) off and vacuum that underneath as well. It might not correct the problem but it won't hurt.
Feb 09, 2011 | Microwave Ovens
Hot point side by side, back of the freezer inside by the fan keeps building up ice and freezes up the water tube for the ice maker, it will build up enough to hit fan.
if there's ice on the inside back wall of the freezer you have a defrost problem.i need the model number so i can help you.open the fridge door,look up on the right hand side up near the ceiling and you'll see a tag with the number,if it's older look down near the bottom hindge near the kick plate
Feb 02, 2011 | Hotpoint Refrigerators
Fridge keeps freezing
Can't solve your problem, but just to report we have exactly the same issue, a huge block of ice forms on the upper rear panel. The compressor seems to be running 24h, not matter where the 'thermostat' is set.
I suspect that there was/are a faulty batch of thermostats. Or (since there is no metal cooling plate to bolt it to) that the T/Stat probe has somehow come adrift from its correct sensing area and is not correctly sensing the temperature inside the fridge.
If I get to the bottom of the problem, I will re-post here.
Dec 06, 2009 | Refrigerators
Leak - water not evapourating
Apr 02, 2009 | Westinghouse Refrigerators
Samsung model srs536 side by side . Water leaking from freezer side. Can you help
There is a drain hole behind the panel in the freezer section. Turn fridge off and pull the power plug. Remove all shelves from freezer.Remove the bottom (larger) panel, about 8 screws. Right at the bottom you will find there will be a build up of ice. You need to defrost this ice and allow the hole to defrost. This can be done by gradualy pooring hot water. Do not try to scrape the ice as you risk damaging the defronst thermastat. From the rear of the fridge remove the inspection panel at the bottom. On the right side as you face the rear you'll see a tube.(maybe white). this is were the water SHOULD come out. It just goes into the plastic tray underneath and evapourates. As you defrosts the ice inside, it will take some time. You will start to see your hot water pouring out of this tube. Placing a small container under the tube is a good idea. Make sure the tube is free from any gunk and is flowing freely. Replace all the bits and you should have fixed your fridge. Note. that turning off the fridge at the power source for over two hours allows the computer in the unit to reboot and solve any defrosting issues it may have with its self. Hope this helps. Good luck.
Jul 10, 2008 | Samsung Refrigerators
My fridge won't keep temp..
most samsung have a fan in the fridge and an evaporator. take off the back plate of the fridge and melt off and excess ice especially round the fan.; if it keeps happening then you have a fault in the defrost system
May 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
