Question about Car Audio & Video
My 2001 forester has the 6 disc changer, it was working fine last week but now when I push the cd button or even the load button nothing happens, everything else on it is working fine. Any ideas?
    Sergeant:
  • 166 Answers
Could be a fuse, or an internal mechanism is worn and has jammed.
Sounds like a trip to the dealer is in order.
Posted on Apr 12, 2015
Disc will not load into subaru forester cd changer
This also happened to my 2002 WRX. I took the CD player out of the console and found a tiny spring (which I could not find) was not in its location, which would actuate the "play CD" switch inside. After a few hours I decided to reassemble the player and use it as a non-CD unit. The radio and cassette player still work, so I purchased a cassette MP3 player adapter so I can plug in my cell phone and play songlists.
May 09, 2014 | 2005 Subaru Forester
Re-setting of cd changer
A couple of different possibilities here but this is a typical problem when it comes to the MB cd changers. Before ruling the cd changer bad, check the spring settings on the sides of the changer. Make sure they are in the 'H' position since it sits in the glovebox. The Mercedes cd changers don't have a reset button. 95% of the time its the cd changer that is bad when this scenario happens. Its caused by a linkage that gets knocked out of place internally of the cd changer. Also try not to use burned or homemade cd's as they can also cause the cd changer not to read the discs anymore.If your cd changer is brand new or a factory rebuild then the dealer should change it out no problem since MB cd changers are known for this problem. Also the version coding needs to done to configure the D2B fiber optic ring properly.
Aug 14, 2012 | 2001 Mercedes-Benz C-Class
Mazda5 6-CD changer stopped working
Hi! I am experiencing the same thing! Have you find any solution? Thank you!
Mar 19, 2010 | 2008 Mazda MAZDA5
The 6 disc magazine will not eject -
Ok..just happened to me. I'm a tinkerer so it's assumed that everything is out of warranty. The low down and skinny is this. The last disc holder is stuck on the metal changer tab, preventing the magazine to eject. 1. Remove the six screws on the left and right sides. 2. Use a small flathead screwdriver to GENTLY pry off the front Alpine CHM-S620 plastic facia.\ 3. On both left and right sides, collapse and push in the rubber suspension mounts. 4. Carefully remove the vertical/horizontal mount springs. 5. Gently pull off the data cable ribbon. 6. Flip over the changer unit. Use a coathanger to gently push the cartridge back into magazine. **You may damage the cd and last holder. Small price to pay to get things back to working order though. You may also have to wiggle the last cd holder to get it over the metal lip. 7. Reassemble in reverse order. 8. Change out that last cd cartridge so it doesn't jam again. Good luck.
Sep 27, 2009 | Alpine CHM-S620 6-Disc CD Changer
2001 Lincoln LS: CD Changer wont eject CD's. Keeps saying CD ERROR when I press eject then select any of the 6 CDs. Also, it says slots full when I press load and press any of the 6 CDs. I just bought the...
you really need to take the cd changer out of the dash,and then open the cd changer ,is one of you cds is making the problem,ones is remove it should be working fine,good luck
Sep 17, 2009 | 2001 Lincoln LS
07 honda odyssey EX-L CD won't play
I have an 07 honda odyssey EX-L with a 6 disc CD2_bing.gifchanger. It currently has 4 CD's inside. None of them will play. Theradion and DVD work fine but I cannot even choose to play the CDs. They will not load nor eject.
Jul 27, 2009 | Car Audio & Video
Car cd changer problem
cd changer not working in leganza
Jun 18, 2009 | USA Spec SCD-D50 6-Disc CD Changer
Rockford Fosgate cd changer
I have the same problem with the 2006 sentra
May 28, 2009 | 2005 Nissan Sentra
Changer does not work
Had the same problem!! Found the solution here under "Wont Play" question. Push that cd chngr magazine (holder) all the way into the unit and tap with a blunt object( Dont tap too hard,it's plastic!!) screw driver worked for me! Push the eject button and you'll hear the unit working! Pop it in and out and it seemed to unfreeze whatever was frozen!! It finally loaded a cd and started playing again. I checked all 6 and they were okay!!
Thanks support guys for your help!!
I'm now a member!!
Jan 15, 2009 | Alpine CHM-S620 6-Disc CD Changer
Car Audio & Video Logo
263 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
