Question about Alcatel One Touch Pop S7
Touchpad is erratic when pressed
If you touch a key,unwanted key appear one or many
    Sergeant:
    Champion:
  • 219 Answers
Turn down the sensitivity, with my Nokia I can just hoover over screen with my finger on full sense & it will pick it up.
Posted on Apr 12, 2015
Touch pad does not work
Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 27, 2013 | Computers & Internet
Asus Laptop Touchpad trouble shooting
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 06, 2013 | ASUS Computers & Internet
I turned off my touch pad to my acer aspire 5733z and it wont turn bk on
hope this helps
Sep 16, 2012 | Acer Aspire 5733z-4851
Touchpad not active
hope this helps
Sep 05, 2012 | Computers & Internet
Why does my cursor jump around on its own whenever typing.
Its because the palms of your hands accidentally touch the touch-pad causing it to move erratically.
When you type, disable the touch pad. You can do so by pressing a combination of Fn key and the key where it shows a hand pointing below. If you cannot find the key, consult the user manual.
Sep 30, 2010 | Dell Inspiron 710m Notebook
Cursor on my keypad jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
2. Adjust the sensitivity of the touch pad:.
a. Click the Start button and click Control Panel.
b. Click Printers and Other Hardware.
c. Click Mouse.
d. When the Mouse Properties window appears, click the Pointer Options tab.
e. Under Select a pointer speed:, click to move the slider bar closer to Slow.
f. Click OK.
g. Check to see if the touch pad still behaves erratically.
3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
4. After connecting an external mouse, uninstall the touchpad driver from the Device manager listed under the "mice and other pointing devices" category and restart the Computer.
5. Download the Touchpad driver compatible to the Operating System installed on the Computer from the manufacturer's site and install it after restarting the Computer.
Good luck!!!!!!!!!!
Sep 18, 2009 | Dell Inspiron 6000 Notebook
Inspiron 1545 keyboard problem
This is going to sound really weird but I found a fix. I've got a Dell studio XPS laptop and was getting annoyed by the same phenomenon. I discovered the problem was more common when my thumbs were close to/touching the touchpad. I cranked down the sensitivity of my touchpad and things got a lot better. Probably works for many different kinds of laptops.
For my machin - Steps to fix:
Mouse Control Panel: Dell Touchpad Tab: Click to change Dell Touchpad Settings: Touchpad Settings: Touchpad Sensitivity: Move it from near "Light Touch" to the middle.
I hope this helps someone. :-)
Jun 18, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Dam that backslash
The \ key appears to be stuck. The keyboard is about $20 part and can be purchased on EBay with ease. Takes bout 15 minutes for a novice to install. The keyboard may resolve the touchpad issue too.
If the touchpad is still erratic after the keyboard is replaced, Flash the BIOS to latest version available and see if any change. If not the palmrest assembly will need to be replaced (About an hour job) or use an external mouse
May 31, 2009 | Dell Inspiron B120 Notebook
Inspiron 1525 Touchpad has a mind of its own
I have had the same problem.  This may sound strange, but try the following:
Switch off the notebook.
Remove the battery and keep the on off switch pressed for >5 seconds.
Replace the battery and start the computer again.
The problem should then be resolved.
Mar 19, 2009 | Dell F3534 Touchpad
Touch pad on/off utility
Disabling or enabling the TouchPad The TouchPad is enabled by default. To change the enable/ disable the TouchPad setting: 1 Click Start, Control Panel. The Control Panel window appears. 2 Click Printers and Other Hardware. 3 Click Mouse Properties. The Mouse Properties window appears . 4 Click the TouchPAD ON/OFF tab. The TouchPad ON/OFF tab appears. 5 Select Disable or Enable, whichever is appropriate. 6 Click Apply.
7 Click OK. The Mouse Properties window closes. 8 Close the Printers and Other Hardware window . 9 Close the Control Panel window.
Nov 11, 2007 | Toshiba Qosmio G25-AV513 Notebook
Alcatel One Touch Pop S7 Logo
41 people viewed this question
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
